The fridge isn't getting cold/ freezer doesn't freeze. Additionally the digital thermostat display doesn't seem to work- it keeps changing- open the fridge door it will say that the fridge is 33 degrees and the freezer is -5 degrees, close the door come back later (doesn't matter the time 15 minutes or 5 hours) the temperature will read different, ie 49 degrees for the fridge and 29 for the freezer, and in the meantime its not cold/ or freezing.
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
SOURCE: frigidaire model frs3r5esb1 stainless steel making
There should be a thermostat for you to adjust the temperature setting.
SOURCE: I JUST REPLACED THE ICE MAKER IN MY FRIGIDAIRE
look for an
adjustment behind the plastic endcover with a +/- on it. - is less water.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
