Question about Jenn-Air WW27430P Stainless Steel Electric Double Oven
Dim display. On my jennair double oven, the display is dim. But everything else works fine. Any ideas on which part to replace?
  • 4 more comments
  • gene1222 Nov 30, 2008
    My Double Oven Model JJW9630AAB had the same problem. I replaced C33 capacitor as recommended by dave1812 in Solution #2 and it now works perfectly and saved me 150 bucks. Thanks Dave. Electrolytic capacitors fail quite often due to excessive heat which dries out the electrolyte contained within them.
  • Anonymous Dec 04, 2008
    I replaced the C3 capacitor with a 68uF 35volt.
    It was brighter, but the cap over heated.
    Any ideas why?
  • mdbeam Mar 19, 2009
    The display on my jennair double oven, Model #WW27430P is totaly dim & can't be read at all. But everything else works fine.
    Can I do the replacement myself
  • chrisxpress Mar 24, 2009
    Dim display, where can we get a C33 capacitor and are there many different kinds of C33 capacitors??
  • gene1222 May 11, 2010
    My previous post stated capacitor C33 by mistake. It is capacitor C3 (68uF @ 35V) that needs to be replaced as discovered by dave1812.
  • Jeff Wood Dec 31, 2012
    Thanks to all on this thread, I saved $248. I watched a YouTube video on de-soldering and then soldering. Next I picked up a 47 MF capacitor from Radio Shack. Then I removed the defective capacitor and put in the new one and cut off the excess wire, soldered it and it worked. It was my first attempt at soldering so might as well try it -- it's better than wasting $250 on a new circuit board. Good luck.
The display sits on a circuit board. Pull the board out and replace capacitor C3. It is 68 micro farads. I used a 47 from Radio Shack and it works great. If you can find a 68, that would be ok too, of course!
Posted on Nov 30, 2008
    New Friend:
My Jenn-air double oven had the same dimming issue. Thanks to the folks on this site, I got the nerve to try and fix the C3 capacitor.
I first watched a YouTube on de-soldering and then went to Radio Shack for a 47uF capacitor. I took the defective one off the circuit board with a de-soldering tool and replaced it with the lower rated capacitor and soldered it on and it worked.
I was a little nervous about doing it (I haven't soldered much) thinking I had a 50/50 chance of success but I hated the thought of paying $250 for a new circuit board. So I would encourage others to at least try before ordering the part, what do you have to lose?
Posted on Dec 31, 2012
Jennair had me replace entire clock
Posted on Oct 13, 2011
  • 943 Answers
HI thanks for your question. the only part to replace is the clock itself .its a common problem with these clocks thanks the appliance doc.
Posted on Oct 12, 2008
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
How do I light my Jennair gas oven? The burners are working fine but oven will not turn on. Igniter was just replaced.
You need a new gas regulator on this oven to get the oven to work properly. This is a simple repair and can be performed by you!
Oct 20, 2009 | Amana AOGD2750 Gas Double Oven
Jennair 30" wall oven display is totally off.
Part # 71003424 runs around $185.00
It's a common issue in Jen-air ovens,the display burns out,the control itself will still work fine but you just can't read it.
Sep 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air oven display blank. Only works when oven has heated up.
I had the same problem and just fixed it myself today. Not sure if your timer board is the same but I replaced capacitor C3 35volt 68uf. I also have the dark spot on the clock glass in the corner but it still works. I purchased the cap from P10292-ND. I also replaced the cap next to it 35volt 470uf P10301-ND not sure if that was necessary but it smelled a little burnt. The display is normal brighness again - total cost 1/2 hour of my time and $4 parts and shipping. Digi-Key is great I ordered the parts on Thursday 7/23 and got it today 7/25.
Jul 21, 2009 | Jenn-Air Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Display on my Jenn-Air electric wall oven is very dim
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Jenn-Air WW27430P Stainless Steel Electric Double Oven Logo
838 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
