Question about Megxon Z6 Digital Camera
Megxon k88 camera
Hi my camera will not turn on correctly.
when the power on button is pressed with the power supply is connected the welcom srceem comes on with the control display buttons than turns it self of after a short perion of time.
and without the power supply connected and fully charged battries the welcom display does not come on but the control buttons light up but do nothing.
can you help as it is only 7 months old and not damaged in any way?
thanks mark
4 Suggested Answers
SOURCE: megxon k9
i have founds a local firm to deal with this
thanks
Posted on Dec 04, 2008
techjuli
  • 157 Answers
SOURCE: megxon k1, battery doesn't hold
Wow, I really hate being the barrer of bad news.
It sounds like the copper conductors (you can see these on both the battery and if you shine a flashlight into the battery slot) arent, well, conducting.
This is pretty common but not exactly a fix it yourself option.
I was going to suggest that you go to the site and speak with one of the customer service reps, but oh wow, have you seen this site? It really looks like it was built by a 12 yr old trying to induce eplilleptic seizures. They have contact information (only a phone number in taiwain and an email), but I dont know how much help they will really be...
The fact that you bought this on ebay is what made me cringe. I hate Ebay sellers that purposely sell lemons. If it has been less than 30 days, you can usually file a complaint with ebay (on their website) and get a refund from the seller.
Hope this is of some help,
TJ
Posted on Dec 15, 2008
landsend
  • 1066 Answers
SOURCE: how to get back erased memory on megxon K38
You can't...sorry  Once it's gone it's gone!
Posted on Mar 22, 2009
E:91:01, no flash
Hello! Welcome to FixYa!
Error E:91:01 is usually comes in Sony Cyber Shot Cameras
To solve this first of all Turn OFF the camera and Remove the battery or the power supply. Now turn the switch to camera for about 30 sec and Turn the switch to OFF. Now Install the battery or power supply and turn the switch to memory. Open the LCD cover and press the RESET button ( small inner button ).You will be prompt to adjust date/time. Set it and now take some pictures.
I hope error will not come but if you still face it then best option is to take it back where you purchased it or contact Sony service center about the error code.They will surely solve it.
I hope this solution helps you.
Thank you for using FixYa, Keep Visiting!
Sep 12, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
I have an E91-01 error message which will not correct itself after reinitialising. How can I solve this? The camera is a Sony DSC W50. Thanks
Hello and welcome to FixYa!
To solve the error E91-01 error, Please follow the instructions given below:-
  • Turn the camera OFF
  • Remove the battery or the power supply
  • Turn the switch to CAMERA for about 30 sec
  • Turn the switch to OFF
  • Install the battery or power supply
  • Turn the switch to MEMORY
  • Open the LCD cover and press the RESET button ( small inner button )
  • You will be prompt to adjust date/time. Do it
  • Now Take some pictures
Error will be removed, If still occur, Perform the above steps once more, after it if still error prompts then it means that service is required by authorized service and they should change the flash unit, In this case go to authorized SONY Cameras service provider, Your problem will be solved.
If you have any more Confusion, questions or issue regarding your problem do inform me.
Thank you for using FixYa!
May 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My camcorder comes up with a repeated message saying press the reset button, it swallows the tape, any help?
First try removing all power from the camera, the main battery, any power supply, and the backup clock battery. THEN press the reset button and hold it for at least 15 seconds. Then replace the internal battery if it is dead. Then if the camera still does not operate correctly, it probably needs repair.
Nov 30, 2010 | Panasonic NV-GS35 Mini DV Digital...
Printer goes on & off not staying on but a couple seconds
Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart c6180 repeatedly turns off about every 10 seconds
Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power button c01941590.gif Illustration of pressing and releasing the power button
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Can not eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 11, 2009 | Sony Handycam CCD-TRV318 Camcorder
The cassette is stuck and the player will not eject it. when you turn it on it just makes a beeping noise.
Aug 11, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Power problem to cmputer
Kindly check the connection from the front power button to the motherboard. The front power button wire may not be plugged into the correct jumper.
if that wire is hooked correctly, remove the memory modules from the system and all other wires from the board , except the power supply connectors to the board and then power it on , check the status of the light on the power button.
if you can provide us with the model number of the motherboard , we would be able to help you better
Thnaks
proton
Mar 12, 2009 | Intel Motherboard
Help please
see if keeping the power button pressed continuously without
releasing keeps the camera on
Jun 15, 2006 | Vivitar ViviCam 5340s Digital Camera
Megxon Z6 Digital Camera Logo
159 people viewed this question
Top Megxon Cameras Experts
Are you a Megxon Camera Expert? Answer questions, earn points and help others
