Question about Toshiba Satellite A135-S4527 Notebook
Dell XPS m1330 Loud CD/DVD Drive Problem
i've got a problem with my laptop cd/dvd driver..
the cd actually stuck inside and when i use to run the laptop it will boot from my cd and i'll not get my widow screen..any help plz..
  • 64 Answers
Good day,
try to look for a very tiny hole near the cover of your cd/dvdrom drive. if you locate this one, you can use a thin wire (straigthened paper clip will do) and push the wire through the hole until you fill some resistance. at this point, your cd/dvdrom drive cover should dislodge and you can eventually open it and get your stuck cd.
i hope this helps.
Posted on Oct 12, 2008
Dell xps m1330 dvd slot cannot load. if cd/dvd is inserted, it is ejected instantly.
Update firmware version from the support site. support .dell.com enter your "service tag" to get proper device driver then flash or update latest BIOS software from the support site aswell
Sep 29, 2010 | Dell XPS M1530 Notebook
My PC won't allow me to right click to choose the eject option for a CD. I want to know if there is a way to remove the CD manually.
The DVD drive itself has a small horizontal 'eject' button that you can press to eject the disc.
If the button fails the disc is stuck however the DVD drive will have a small hole near the eject button- about 2mm in diameter. Straighten a paperclip or similar and push into the hole until the disc drive mechanism releases and opens.
Thanks,
Javaftper
Aug 07, 2010 | Dell XPS M1330 Notebook
My dell laptops xps m1330 dvd player is not working
Verify that you have the last firmware (A14) on the Dell Support web site. Then check the CSS status of the DVD (should be unlocked) with this utility
http://www.digital-digest.com/software/download.php?sid=2&ssid=0&did=1
and finally verify that the DVDs are actually readable, and that the DVD reader works (try reading / burning a data CD-ROM or data DVD).
Check also that the video player software is set to the correct region and there are no errors in the Event Viewer (Hit Start, choose Run, type EVENTVWR.MSC and Enter). DVD events should be either under System or Applications.
Apr 15, 2010 | LG GCC 4320B CD-RW/DVD-ROM Burner
Hi, I have a dell XPS laptop and the cd got
When you get a cd stuck in your cd player there is a small pin hole near the push buttom in front stick a pin in it and it should release!
Dec 12, 2009 | Dell XPS M1330 Notebook
My dell xps m1330 will not boot up.it comes up on screen saying ''no boot sector on internal hard drive'' ''no bootable devices''it has had a new motherboard fitted by Dell.i'm trying to install xp pro
When it's booting, try to access the setup, aka BIOS. See if you can set CD/DVD as a booting option. As the top BOOT device. Then see if you can boot your installation CD. You may be able to format your drive during the installation - if the hard drive hasn't failed?
Nov 23, 2009 | Dell XPS M1330 Notebook
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dvd stuck inside slot drive, system had crashed
hello..to get out you`re CD/DVD its very simple you need a small Pin like a paper clip then find the small hole the front side of DVD/CD player and push the hole using the paper clip..about this question kindly Verify>(plus i had already installed the new hard disk because the old one crashed)..what is it??...Thank you
May 08, 2009 | Dell XPS M1330 Notebook
Dell xps m1330 cd/dvd problem
there is a small hole on the CD door. use a small paper clip, and strighten out one end and inssert it into the hole and push. the door should open halfway. pull out the cd and push the door close. it wil not damage the CD, or the drive.
Oct 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
