I have sansa headphones e260 the wire is coming loose out so soon I think my headphones wont work I need help :(
    Master:
  • 763 Answers
Just buy or change your headphones with a new one to be able to use your device again.
CHARCOIS
Posted on Oct 12, 2008
My Sansa will only play through the right speaker/headphone unless you jiggle the cord and hold it in the perfect spot, then it will play through both speakers/headphones. Is there a way to fix this...
This is a common problem, it is the lead in the headphones get a new headphone set that will sort you,IF it is the actual jack, soldered onto the motherboard, this then will required to be resoldered. I think, however just replacing them will work fine.
Apr 01, 2010 | SanDisk Sansa e260 MP3 Player
Choppy audio on Sansa e260.
To me it seems like the head phone jack is loose, it might need to be re soldered and then things would be back to normal. HOpe this works.
Wayne
Jun 26, 2009 | SanDisk Sansa e260 MP3 Player
Jack problem
This unsually indicates a bad connection with the jack. Not the headphone jack, but the connector on the player. My son had that issue so I ended up opening the unit up and resoldering the connector to the circuit board. Don't recommend doing that. You'll need to have a technician do that or if it's still under warranty take it in.
Apr 16, 2009 | SanDisk Sansa e260 MP3 Player
Loose headphone connection on mp3
Replacing a headphone jack on a Sansa is a risky endeavor that is bound to do further damage to your player - the original jacks are not orderable directly from Sandisk. Your best bet is to call Sandisk and get an in-warranty replacement.
-Tha Mp3 Doctor
Mar 11, 2009 | SanDisk Sansa e260 MP3 Player
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
I cant get my computer to recognize my sansa e260
I couldn't get my e260 to work at all. Came to fixya and was able to reformat. Comes on now but can't get computer to recognize it and also will not let me set date and time. (time and battery level do not even show up on bottom of e260 screen). Help!
Sep 08, 2008 | SanDisk Sansa e200 MP3 Player
Internal Connection
Just buy new headphones!
Mar 16, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Hi, I have the same problem but sometime is the left channel & sometime the right channel. I tested multiple headphones and it's alway the same problem. FYI the problem begin after a firmware update. With the original firmware the problem never append. It start with the firmware ver. 01.02.15E. Today I have downloaded the new firmware version (01.02.18E). I hope it fix this annoying bug. Bye
May 01, 2007 | SanDisk Sansa e260 MP3 Player
Audio Problems with Sansa e260
apparently you may need to defragment your player with disk defragmenter because the mp3 has a hard time getting the pieces of your file fast enough to not hear an almost unnoticeable pop or crackle. if this isn't the reason, it is probably the jack, try a different pair of headphones even. or check the settings on the program synchronizing as it may be syncing the files at a noticeably lower sound quality. Or you are drag and dropping which may not be recommended for inexperienced users. no offence :).
Jan 28, 2007 | SanDisk Sansa e260 MP3 Player
59 people viewed this question
 Grubhead
Grubhead
