Question about Karcher 2500 PSI Pressure Washer
My Karcher HD 1050 DE has lost pressure, ive had new valves put on it but still has no go in it
  • 47 Answers
Could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
Posted on Mar 09, 2009
My pressure washer has lost pressure and has water coming out of a small outlet i assume to be a pressude release device;can this be fixed or replaced ?
that's probably the unloader valve all it might need is a quick dissasle to see whats gumming up the works , as all I was able to find for sale for that model here was a new gun and the soap injector for about sixty bucks each , you might have to look around in the Uk for one as that's were there most popular
Mar 18, 2016 | Karcher Garden
How do you change a rupture disk for karcher 3600 4.0 GPM
try putting a plug and then try again if you hear the pump not unloading when u release the trigger then the new rupture disk would rupture due to a faulty unloader you can use a pressure relief valve for a better replacement.let me know 30 years exp,
Jul 28, 2013 | Karcher HEX HD SCREW 1/4-20x1.25
I have a Karcher HD 3101 pressure washer. The out pressure is not working. Is there a unloader valve that needs to be cleaned?
Yes, the unloader needs to be lubed. Send me a email at justin@wmpcs.com with a discription of what you just listed and I will send you a pdf file on how to repair it.
Sep 27, 2010 | Karcher G3025OH Pressure Washer
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher g2500vh..sheared off spill valve
I've seen that before many times. If you have removed all the broken parts you can purchace a new spill valve, grease it and install it. If not, you need to remove the pump and sit it brass side up before removing the bolts holding the brass to the aluminum part (you have to do it that way so the oil doesn't spill out. CAUTION: there is some spring tension on the brass head.), find the other pieces of the spill valve, then put it back together. Then you can buy a new spill valve and install it. there are several on-line companys that sell spill valves for karcher machines, but most of then you would need to call to get the part number and price. I'll help you out by giving you the part number.
Part #4.591-040.0
If this helped please rate it.
Bill
Jan 22, 2010 | Karcher 2500 PSI Pressure Washer
My karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Apr 25, 2009 | Karcher Garden
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
940 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
