Question about Nintendo DS Lite Console
No ds card read - Nintendo DS Lite Console
  • kevinwilkins Oct 14, 2008
    I have a SD card that i have loaded some games on when i put the card in the DS just says loading and nothing else?
  • 4 Answers
Since most ds's don't use SD card, I'd say contact the uhh, maker of the card you're using? Chances are your software is bad, needs updating, etc... Or your SD card could be bad... try another and see if it still happens.
Posted on Oct 17, 2008
When games are inserted into console they will not play
If you are inserting a DS card, be sure there are no foreign articles inside the slot. Blow into the DS card slot to clear any debris. Also be sure you are inserting the card all the way in until it clicks. I've also found that if you're powering on a game, and you bump, grasp or touch the ds card as the DS is powering on, that can cause it to not read games.
Check the actual DS card itself and carefully look at the exposed contacts on the circuit board. Be sure none of them are scratched, damaged or otherwise. A scratch can damage a contact, thus preventing proper data read.
If anything was spilled onto the DS card, be sure it is thoroughly cleaned with a damp cloth (no cleeaning chemicals!) If you immerse the DS card, or pour liquids on it, that may damage it as well.
Same points hold true for inserting a Gameboy Advance game (if you have a DS or a DS Lite. The DSi and DSiXL do not have Gameboy Advance slots.
If you turn on the DS and nothing happens, try a different DS Card. If it only happens with that one particular game (or games) your DS cards are damaged or need cleaning. If all your games are not playing, there is a problem with your DS. Try your games in a friend's DS just to make sure. You'll probably have to send the unit to Nintendo for repair, or take it to an authorized repair center.
Dec 05, 2010 | Nintendo DS Console
DS Lite Console: my nintendo ds lite won't read game cards...
try compressed air.
more then likely its a hardware issue. try getting an R4DS card and download games from www.filestube.com if you dont want to repair it.
you can have 50+ games on an sd card and not have to lug around all those games anymore
May 06, 2010 | Nintendo DS Lite Console
Ds cannot read my r4 card why?
my ds doesnt read my R4 it ? menu dont what happened but it reads other cards can someone help please
Oct 03, 2009 | Nintendo DS Lite Console
DS doesn't read game card
if your games doesn't load this cuold be your problem
you mite have a dirty game or something is in the slot....
....icelord
Jul 31, 2009 | Nintendo DS Lite
My NDS don't read the card.I download the software and games correctly but when I put the R4 with the Micro SD in the DS the DS tell me that don't have any card.
you either have a naff fake card or your ds has a prob with the pins inside that read the games, if you try ur ds with another game and it works ok then its the r4 card at fault, try it few more times then try return it 4 refund, i had couple duds too thats y i use dstt cards from www.dealextreme. cost less than 5 gbp! and free delivery and all mine work. good luk.
Apr 09, 2009 | Nintendo DS Console
DS light wont read the cards
may have problem with the pins in the cartridge slot that reads the game data
Apr 07, 2009 | Nintendo DS Lite Console
Ds lite not reading games
The game is old and maybe not treated with care. Mail it to palm coast, fl.
Dec 28, 2008 | Nintendo DS Lite Console
Can't save or erase
Hmm, this can be several problems.
It may be that the game is damaged or the DS isn't reading the game card correctly.
This is usually due to dirt or other artifacts on the metal contacts on the bottom back side of the game card.
These metal contacts need to touch the metal contacts inside the DS in order for it to read.
It is also common that these get scratched up and harder for some DS machines to read.
Best ways to deal with this is you use a small Q-tip and dust off the contacts on the card.
The contacts in the DS can get dirty, but are hard to clean.
If you must, I suggest using a can of air to dust it out.
A Q-tip would only make things worse as they often break apart and the DS game card contacts are hard to get at without opening the DS itself.
If those fail then there's one final solution.
Send the game card to Nintendo for repairs.
If it is no longer under warrenty it'll cost you a fee, but they'll repair or replace the card for you.
I'd suggest checking the card in differnt DS machines to see if its just your DS not reading it right or not.
A good cleaning usually does the trick though.
Hope that helps.
Good luck fixing it.
Dec 13, 2008 | Nintendo New Super Mario Bros. for DS
Ninetendo DS keep receiving message "Could not read the data"
what ds card you are use? e.g. ds-one, supercard... etc ?
You might have a driver loose, try to re-copy all ds card driver to your memory sd, within cd support included of the pack,. or you'll need re-format your sd then copy your game at the right folder.. and try again..
Hope this helps..
Nov 30, 2008 | Nintendo DS Console
DS Lite unable to read DS game card
try to use rubbing alcohol on a qtip and clean the game connectors and inside the game slot. Or try to blow on it. that usually does the trick
Aug 19, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
52 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
