Question about Ariston Technologies AW 149 NA
Ariston washer margherita a i b 14
F o 8 displayed on window
SOURCE: ariston margherita washer dryer awd12
To dry you need to turn the program to the little 'star' sign after the program 8 and not before. You then need to select the time you want the dryer on for, if you don't select a time the dryer doesn't come on...........not filling is a problem, it may be ythe electrics or it may be that there is something wrong with the door -if the machine thinks trhe door isn't closed it won't fill up but this machine generally uses a small amount of water and wil not actually fill up as such anyway......hope that helps!
M
x
Posted on Nov 21, 2007
SOURCE: F-05 on Ariston Margherita AIB 16
i had the same problem. try emptying the little chamber at the bottome front of maching. there might be something in there. then have a look at the little grey fan thing. give it a push. if it springs back it is working if not it is broke. tip the machine on its side and undown the filter part. ordr this section online. it is easy to replace. i done it myself. Lu
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
ginko
  • 19396 Answers
SOURCE: Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Posted on Apr 18, 2009
  • 10 Answers
SOURCE: we have the Ariston Margherita front loader
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on May 17, 2009
I have an Ariston Margherita (secondhand) washer/dryer, probably some 14 years old. It washes fine, but the dryer tries to work, but the drum no longer rotates. Is it worth trying to fix it, or shou
Given the age of the unit, I'd price newer ones, both at stores and secondhand on Craigslist, then go to Google Shopping or your local appliance-repair place and get a cost estimate for the drum belt and the motor. Whichever costs less, that's your best option. (It'll probably be a secondhand-but-still-newish one on Craigslist, as Ariston parts are getting really pricy nowadays.)
Aug 30, 2012 | Washing Machines
Please kindly supply operating manual for Ariston Wash Machine Margherita 2000 AB40
I have just typed in 'Ariston washer manuals' into Google and it has returned many sources. It should be possible for you to find one there.
Fixya tends to give instructions and guidance from people like me (retired Englishman in SW France @ 14:16 Sat afternoon) rather than the direct supply of manuals.
Cheers,
John C
Jan 29, 2011 | Washing Machines
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Technologies AW 149 NA Logo
57 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
