Question about Sony Playstation 3 (PS3) Console
Slow download with PS3
I have tried for the past few days to solve a download issues. I used to be able to download at a rate of 200-300 kbps wireless. now I'm down to 70 kbps wireless or 80-100 kbps wired. I have got the new Belkin N1 which shows on screen the download rate. it states 800-2.5 Mbps. I have down speed test on my laptop and it coherent with the router.
I have tried different setup (channel 11 vs 1, manual configuration ...) and still the speed stays at low level. I have also check with my ISP provider and it is all fine on their side.... so now I'm a bit lost and about to go into depression!! A demo game download of 750 Mb takes about 3-4 hrs .. in the best days! all my friends living near me are able to download in about 1hr max...
can anyone give me further advices? there must be an issue with router, firewall, setup...??? Thanks so much... PLEASE put put of my misery!
  • sth04 Oct 12, 2008
    I have tried everything you mentioned (except the INterface Robustness, which I can't find anywhere in the Belking setup). Still the download rate remain exactlythe same.. no change. I have wired the PS3 directly to the router.. speed is marginally better but still far far awar from what it should be.
    I have disabled UPNP, selected different speed on PS3, I have added manually the DNS server provided by my ISP, Set the MTU at 1492, got NAT type 2. ... and still it is driving me mad!
    oh and I have the latest firmware ...
    but is this not going away from the principle of playstation and be able to download stuff on it?!
    Sergeant:
  • 352 Answers
PS3 in all actuality is a server and you can contact Sony to get the specific internal server address. Once you have this information you can use an ftp client such as Filezilla to download and upload what ever files you choose. I am a webdesigner and I use ftp for all my major uploads/downloads( 20 Mb to 1G and up). Once you start gathering your info and get to a point where you need more help post a non specific question toward me and I will assist you further, good luck.
anaanymous
Posted on Oct 12, 2008
  • anaanymous Oct 12, 2008
    One other thing you might try is to access the security center in the router itself type in the url bar the routers IP address and see if you can get in, if you can you can configure all kinds of stuff, wep, wda, set key access codes etc.... Give it a try, what do you have to lose at this point..
    192.168.1.1 192.168.11.1
    p.s. type in just numbers no http:// or www
  • 1,031 Answers
If possible connect your PS3 directly to your broadband connection, to see wether your router is the problem or not. If you are connecting your PS3 to a router through a wireless link, then you should test with a wired connection, to make sure its no a bad wireless link that is the problem. If it works better wired, then you can keep it wired :) Or try to improve the signal path between the PS3 and the wireless router, mainly by moving the position of the PS3 and router around and see if it improves. Look for a firmware upgrade for your router it might contain improvements that will help. There are many things that can impact a wireless link, noise from other radio sources in the same frequency area, like the wireless phones, leaky microwave ovens and no line of sight between the PS3 and the router. If you got other units also connecting to the router at the same time, try to turn them of to see if that helps. Now if its slow with wired also, then you can try to turn off UPNP on the PS3. Information on UPNP you can find http://en.wikipedia.org/wiki/Upnp Wether your router supports UPNP or not, you need to check the userguide that came with your router or maybe its listed on the router manufactors website. As a sidenote some routers may support UPNP, but could have bugs in their UPNP code. If you are on DSL you can try to change MTU setting to 1492 to see if that helps, it should atleast help people on DSL with PPPoE if the PS3 fails to automatically detect the proper MTU setting. In general it is set to 1500, but sometimes we need to lower it to smooth the transmission a bit. You can also experiment with the Ethernet data transfer rate and operation mode. Some ethernet chips just doesn't like each other enough to work reliably on the auto setting. Check your router to see what speeds it supports on its port, the common stuff should be: 10mbps 10mbps 100mbps 1000mbps Setup the PS3 to use what your router supports. When you do a connection test on the PS3, you should get a NAT type result (http://manuals.playstation.net/document/en/ps3/current/settings/connecttest.html) Ideally you should atleast have Type 2 to avoid know issues and still have a router running. There are 3 types NAT Type* Displays how the PS3? system is connected to the Internet. Can be helpful in determining connectivity with other PS3? systems when using voice / video chat or the communication features of games. Type 1: Connected directly to the Internet Type 2: Connected to the Internet via a router Type 3: Connected to the Internet via a router. Depending on the network environment it may not be possible to connect to other PS3? systems. Voice / video chat and the communication features of games are restricted. There could also be that you are hitting the network at peak hours and that is an issue.
  • Starnley Johnwells
    Starnley Johnwells Oct 12, 2008
    Also another tip from me is to wake up early in the morning and do it before leaving for work or whatever, because at that time its not as many people as throughout the day. This makes the servers more free and allows faster download speeds.
    There could also be an issue that you are hitting the network at peak hours .
    President:
  • 2,712 Answers
Turn on "Interface Robustness" in the wireless options. Also disable UPnP in both PS3 and your router.
Try to be as close to the access point as possible.
  • Swilin Sampson
    Swilin Sampson Oct 12, 2008
    improves.
    router.
    Information on UPNP you can findhttp://en.wikipedia.org/wiki/Upnp
    10mbps
    10mbps
    100mbps
    1000mbps
    result
    http://manuals.playstation.net/document/...
    NAT Type* Displays how the PS3™ system is connected to the Internet.
    Can be helpful in determining connectivity with other PS3™ systems when
    network environment it may not be possible to connect to other PS3™
    restricted.
  • Swilin Sampson
    To get NAT 1 you must connect your PS3 directly to your broadband
    connection, ie bypassing your router. Usually that is not a very good
    idea security wise, so I would not recommend you do that.
    The problem is that all routers are not equal, you need to get a router
    actually shows up as Type 2 when you do the test. This is because all
    vendors have their own tricks when they create NAT functionality in
    their routers.
My PS3 connection isn't working very well. Please help me!
If you found speeds that low,do a speed test on something else in the same area of the house(laptop) with the same site simultaneously.If you don't get a similar result.you know it's the PS3.If you do get a similar esult,retest the laptop closer to the router.If the laptop is now OK,then you've got some interference somewhere.If this is where your diagosis took you,consider running an Ethernet line from the router to the PS3.If the PS3's Wi-Fi is the trouble,you can get an Ethernet adapter that will run through your coax wiring to the router from Verizon(called a NIM-Network Interface Module).This would be a great option if you have a coax outlet where the PS3 is.Try running the PS3 with an Ethernet cord first to make sure it's just a Wi-Fi issue in the PS3 and not something that is affecting both.
Jun 03, 2012 | Sony Playstation 3 (PS3) Console
I am using tp link td-w8901g router.my internet speed is of 384 kbps for which i have to be able to download at maximum 48 kbps. when i use internet normally, i am having slow browsing. the download speed...
If you are paying for a downlink speed of 384 Kbps you should be getting at lease around 300. First bypass your router - connect your cable/DSL ethernet line directly from the modem to your PC. Go to http://www.auditmypc.com/internet-speed-test.asp run the speed test and see what your download speed is.
If it's less than 300 call your service provider & ask them to check out your line. If they say that you are getting 300 Kbps or more, you have a problem with the ethernet card in your PC. Replace it.
Of course, if your speed is OK when you bypass the router, you have a router problem. Contact the manufacturer or replace it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 30, 2011 | TP-LINK TD-W8901G Router
Hi, I can't uninstall AVG 2011.An error has occurred in it(0xc0070643)
You could try the AVG Remover at the link below. I'd create a new System Restore point prior to using it. Just copy and paste the link in your browser and download your Remover tool
http://www.avg.com/us-en/download-tools
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | Computers & Internet
Could not connected to facebook chat at this time
When that message is shown, it means that the Facebook server is having a problem, either a slow connection or an overload, or your internet connection may have been a little bit slow and didn't load all the data.
Try to reload the page in a few minutes, then your problem should be solved.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Dec 29, 2010 | Facebook Social Network
Very slow and intermittent wireless internet connection
I seem to have solved the problem by downloading the driver from Asus directly.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I pulled out my Asus card, looked up the card model and downloaded the correct driver. Looks like the windows update or the Dell update must have caused the driver to get whacked. Hope this fixes your issue as well.
Apr 02, 2009 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
Slow download speed in 256kbps
Hi Naveen,
The transfer rate is at its optimum for one-fourth the total connection speed.
Since your connectio is 256 hence you should be getting 60-65 average speed.
Try using DAP (DOWNLOAD ACCELERATOR) which is available free from the following site...
www.speedbit.com
Hope this works out.
Reply ASAP if it works.
Thanx.
Nov 08, 2008 | Microsoft Windows Server Standard 2003 for...
RE: router problem
You're welcome. anything to help out.
I'm sure you still have the phone filters installed.
So,
Run a speed test from here.
Then, compare it to the speed that you're paying for. For ex., you might be paying for a 1500 Kbps download and 256 Kbps upload.
If any speed (upload or download) is lower than 50 Kbps, call your service provider and tell them that you are not receiving the reasonable speed you paid for and that you have already cleaned your "cache" (they will suggest that you clean several files from your computer but that does not affect your speed).
Thank you for responding. Its rare for people to respond to helpers.
Aug 08, 2008 | Westell Wirespeed LiteLine 6100...
Slow
how many kbps router u have if u have then problem the compny give u a boud on the slow speed when u reset your router its take a ip thats ip has a slow speed if its fix then u have change it on DHCP if DHCP is off ur router on fix ip & thats ip is slow taht y u have got a slow speed u have to do this reset your router & reconfiger it your problem will solvs
Jul 19, 2008 | NetGear DG834G Router
Update on recommended fix.
HI,
Try changing it to 128kbps and let me know.
Mar 29, 2008 | Audio Players & Recorders
Kaisen P83 - Invalid Viedo File
You need "Total Video Converter" and "Xilisoft 3gp".
1st make a video with your phone. Open the file with Xilisoft 3gp.
Take note of this:
Summary:
Duration: ????
Bit rate: ????kbps
Video:
Format: mjpeg
Frame rate: ???fps
Audio:
Format: ????
Bit rate: ???kbps
Sample rate: ---
Channels: ????
Now convert a video with "Total Video Converter" using the parameters you got on Xilisoft.
I tryed and works well.
Hope this help you ^^
Jan 17, 2008 | Siemens M56 Earbud Hands Free Headset
Sony Playstation 3 (PS3) Console Logo
174 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
