Question about Canon PIXMA MP210 Photo All-In-One Printer
Power and alarm lamp lit error code e 3 flashes indicating a paper jam but no paper is jammed power flashing green 3 times then stays green and alarm lamp flashers orange three time then gos off over and over tried reseting it by holding the resaet butten no luck turning the power off does not work i can not get the ink out it wont let me
  • Anonymous Dec 07, 2008
    me too
    President:
  • 2,712 Answers
Try a hard reset first - Unplug printer from AC power source for a minutes and from PC. After a minute, reconnect everything and power up and see if it works..
Posted on Oct 12, 2008
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Machine has an error code & won't print. We have no manual.
If the lamp is on solid that is a cancel job or reset printer indicator
If the lamp is blinking (flashing) that is the secondary Jam error meaning somewhere in the paper path is a jam. The lamp shoul dbe blinking in a sequense - that sequence indicates what are of the printer the jam is. So the lamp should blink a number of times, pause then blink the same number again.
1 blink - jam in feeder sensor
2 blink - jam in manual feed
3 blink - jam under toner
4 blink - jam in output are
5 blink - jam in tray 1
6 blink - jam in tray 2 (if present/option)
Sep 03, 2009 | IBM Infoprint 1412 Laser Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
May 11, 2008 | Sony DPP-FP50 Thermal Photo Printer
E 2 problem
I've encountered that before, i cleaned that the printer for the paper jam. Then i turn on the printer, it shows an error and flashes green. What we are going to do is to uninstall the current driver, and reinstall it... After that, try to turn it on and wait for few minutes to run the printer properly... try it...
May 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
269 people viewed this question
old marine
old marine
