Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
The door is locked and water is still in the drum. The cycle says complete? I've tried various cycles to see if the door unlocks at the end but now water comes out the door?
  • 70 Answers
Sounds like you have a blocked pump or discharge pipe
Posted on Oct 12, 2008
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
I have a hotpoint WMA63. It goes through the washing cycle, and the water drains but when the spin cycle starts, the 'spin' light just flashes continuously. The drum goes around fine during the...
Hi, My guess is that you have an uneven load in machine. When it's time for the spin cycle to run, it will not complete that spin. You will have to open the door and rearrange the load so that it will spin.( machine will not run when door is open). good luck.
Jun 08, 2011 | Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Washing machine overfilling
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Sep 29, 2008 | Washing Machines
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Hi experts, I have a Hotpoint WMA62. In the past it suffered from the bearing problem, and today it has stopped completing the wash cycle - barely starts it infact. I don't have a warranty and wonder if I...
is this that the drum doesnt go round much or at all when turned on but lets the water in if it is then its just your carbon brushes and will only cost no more then £15 to buy them let me know
May 08, 2008 | Washing Machines
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
291 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
