Question about Indesit W 123 Front Load Washer
Indesit wdg1295 W
Hi
You said you can provide brushes for this machine. How much and what is delivery time? Does this machine use only cold fill? It does have pipes fitted to both hot and cold?
Regards
Ollie Carruthers
Geordierhino
  • Geordierhino Oct 12, 2008
    Motor type Indesco electronic control motor. 940M31. is this enough info. I am in the UK, Hampshire. How much for p&p.
    Regards
    Geordie Rhino
  • Anonymous Feb 21, 2009
    hi
    i have an indesit omega 1100 model wdg1195w , the brushes have gone and need replacing does anyone know where i can purchase a set
    thanks anthony
  • 99 Answers
Aproximate price £22.00 +p&p delivery this week if in UK.Need to now if it is a CESET motor 3 types fitted.Will only fill hot on 90 degree wash.If a problem fit Y piece connector.
Posted on Oct 12, 2008
  • Reg Woolley
    Reg Woolley Oct 12, 2008
    Will post out for £22.5o including p&p.Ring shop monday Quote reg5031684637225woo.with credit card you should recive latest Friday proberly earlyer.regwoolley@uwclub.net
    01270626386
    Returns If for any reason whatsoever you are not happy with your item you may return it within 7 days for a full refund of the purchase price. Please contact us first, so we are aware there is a problem.All items must be returned with all original packaging,Unopened and not damaged, please be aware we cannot refund postage costs.
There is water flowing to the washing machine then straight out down the waste pipe, there is also a noise whilst it does this like a pump? This is when the machine is turned off. It is an indesit machine.
This sounds to me like it is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Indesit Washing Machines
We have an Indesit washer dryer WDG1295. When switching on, it fills with water, hums away as though it is working (including draining) but the drum doesn't turn. The belt looks fine, and if you move the...
Immediate thought was the belt but you already checked that. Reading your message, you seem to be indicating the washer goes through the wash cycle and does everything except turn the drum, i.e. it fills and drains and the timer control knob advances as you would expect. This machine has an electro-mechanical timer rather than electronic, so if it advances through the program correctly, I would exclude this from my initial checks, but I'd still come back to it later.
Washing machines aren't that complicated, so if all of the above is true, the obvious assumption would be the drive motor. You've obviously opened up the machine to check the belt, so have you tested the motor with an ohm / multi-meter?
Please confirm the correct operation of the timer and whether you have tested the motor and I will try to assist you further. I check messages regularly, so if you post back here I should reply fairly quickly. Make sure you reply from within this page - don't post a new help request!
Regards,
BElectric
Nov 27, 2010 | Indesit Washing Machines
When machine is switched on, the programme clicks round and round and the machine does nothing
you may need to reset this put to . positon then switch on machine light flashes several times then pulses..it is now reset should now fill and start motor providing motor is working okay...Brushes not worn....
Nov 13, 2009 | Indesit W 123 Front Load Washer
HELP WITH MODEL W822R
I have recently acquired an Indesit washing machine, model number W822R and like you I was stumped as to how to use it. I too looked on Indesit's web site and could not find a manual for this particular machine. Years ago I owned a very similar machine, but only had a vague recollection of it's operating instructions. I looked through several of the manuals on Indesit's site and realised that there was a common theme running through them. The operating manual closest to W822R is the W101. All the wash cycle numbers match and my washing machine works perfectly with them.
One thing to bear in mind is that a lot of modern machines are cold fill only, whereas the W822R is hot and cold fill, so make sure you have both hoses on the back otherwise some wash programs won't work. The W822r can still be used as a cold fill machine by using a plastic 'Y' connecter, available from most plumbing outlets.
Hope this helps
Dawn
Apr 06, 2009 | Indesit WA 125 Front Load Washer
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Mar 31, 2008 | Indesit W 123 Front Load Washer
Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
433 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
