Question about Sony Ericsson W850i Cellular Phone
Receive or make calls
On my display screen it has a icon with a hand set with a red line through it i still have network coverage and it,s open to any net work and i,ve try-ed other sim cards same thing please help
  • Philip Featherstone
    Philip Featherstone Oct 12, 2008
    it,s still the same after resetting it any other suggestions would be appreciated thanks
    Master:
  • 383 Answers
Please try after resetting your phone .....
Posted on Oct 12, 2008
My words and icons are too big
Hey Ramona Savage
Adjusting the screen resolution setting may be necessary to resolve issues with the display size on monitors and other output devices like projectors.
Here's How:
Navigate to the Control Panel in Windows XP by left-clicking on Start, followed by Settings and then choosing Control Panel.
In the Control Panel window, open Display.
Note: In Microsoft Windows XP, depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
In the Display Properties window, click on the Settings tab.
Locate the Screen resolution slider on the left-hand side of the window. Under most circumstances, the best choice is 800 by 600 pixels or 1024 by 768 pixels, possibly higher if you're using a 19" or larger monitor. The "best" setting is highly subjective to your personal preferences.
Note: Some types of software require the screen resolution settings to be set at a specific size. If you receive errors when opening certain software titles be sure to make any changes here as necessary.
Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
Good Luck
Jul 29, 2012 | Dell Computers & Internet
How to open gprs
By the way, what is the brand of your phone so that I would be able to give you the instructions.
Or I would assume that you are using smart phones.
Smart phones use GPRS to connect to your mobile carrier and allow you to roam. GPRS is the wireless network that allows calls to be made and voice mail messages to be received, and it carries your voice over the airwaves. There are times when you may need to open (turn on) your GPRS if it becomes closed (or turned off). When your GPRS is open, you can select a network to connect to.
1.Press down on the "Menu" button from the home screen of the data device.
2.Click the "Settings" or "Tools" icon for phone configurations.
3.Scroll to and select "Phone Settings" or "Network Settings."
4.Click the options for "Airplane Mode" or "Wireless Mode" (based on your smart phone manufacturer).
5.Select the option for "On" or click the "On Checkbox" to open up your GPRS.
Open GPRS for Network Selection
1.Press down on the "Menu" button from the home screen of the smart phone.
2.Click the icon for "Settings" and then select the option for "Call Settings."
3.Click or press on the icon for "Network Selection" to open the menu and then click on "Default Setup" to access the network configuration options.
4.Scroll to and select "Manual" to change the phone from automatically selecting a network.
5.Select the desired network and make sure that the phone connects. Test the phone by making a call with the new network.
Open GPRS for Voice Mail
2.Click the icon for "Settings" and then click the icon for "Messaging."
3.Scroll to and click the option for "Messages Settings."
4.Click the icon for "Voicemail."
5Make sure that the option for "Voicemail" is set to "On" to receive voice mail messages..
Sep 06, 2011 | Computers & Internet
I am used the sony ericsson w100i...then i'm want to send a multimedia's messages,,,but it doesnt work...how to setting it
activate the gprs and mms settings first.. get the settings from your network provider.. upon receiving the settings, save or install it to your phone.next,activate the mms and gprs profile of your network provider.. you can test if your mms is working by sending an mms message to your own number.. your mms feature is working if you receive the mms.
note:you must have good network coverage or signal if you send mms.GPRS icon must be seen in your phone screen indicating that you are capable of connecting to the network via gprs.this icon commonly appear as capitalized letter G in most of phone screens..contact me if you have other questions. kgangel_16@yahoo.com
Apr 03, 2011 | Cell Phones
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
Red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
May 25, 2009 | Sony Ericsson K800i Cellular Phone
No network coverage on display screen
First, you should contact your service provider to make sure there is coverage where you are having the issue at. If there is coverage, the first step is to power your phone off and then on again. If that doesn't work your service provider can continue with other troubleshooting on their end such as making sure your account is set up correctly.
Apr 21, 2009 | Cell Phones
W850i not calling or texting
your probably on another network to her, you need to get the phone unlocked to any network. Most 2nd hand mobile shops will do this for you for a bout a £5
Feb 17, 2009 | Computers & Internet
CAN'T MAKE OR RECEIVE CALLS OR TXTS
you can also take the phone and ahve the IMEI number changed to be able to use it.
Jun 12, 2008 | Sony Ericsson K800i Cellular Phone
My sony ericsson K850i
check your phone settings. tnx
Jan 17, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
70 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
