have you tried setting the camera on "flash mode"? usually it has a lightning symbol that specifies that you are in flash mode. you can also set it on auto-flash where it automatically detects the level of light and uses flash when necessary.
however, if you have already tried the suggestions above, you may have a busted flash. in this case, you can approach your seller or the nearest service center of fuji.
I have a brand new Sharper Image® Mini Portable Camcorder after 1st charge it won't...
(More)
I have a brand new Sharper Image® Mini Portable Camcorder after 1st charge it won't turn on anyone have the same problem?
i have a panasonic dmc-fz7 lcd screen dosn't work bought a spair repair of ebay camera how does the...
(More)
i have a panasonic dmc-fz7 lcd screen dosn't work bought a spair repair of ebay camera how does the conecter come of the board
Thank you so much for this forum! I managed to fix my camera without disassembling it by replacing...
(More)
Thank you so much for this forum! I managed to fix my camera without disassembling it by replacing the batteries to fresh batteries and rapping the case against the desk a few more times! Prior to that I'd tried all the fixes listed above, short of disassembling it, and nothing worked at all. The lense sounds a bit worn now when I turn the camera on, but at least it's working! It also displays a busy alert before completely finishing the shot taken, but like I said, at least it is working!
