Question about Hotpoint First Edition WMA20 Front Load Washer
Hotpoint first edition washing machine
I have started having problems with two cycles on my machine. When using the silks programme and the quick wash cycle the machine pauses when on the rinse and the lights on the front of the machine start to flash, this doesnt happen on every use but it is becoming more frequent, usually pressing the start button remedies this, but the last time this happened the machine just kept pausing and the lights kept flashing, so I had to choose a rinse cycle to complete the programme. Any help with this would be greatly appreciated.
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
  • 209 Answers
SOURCE: Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Posted on Sep 18, 2007
  • 1294 Answers
SOURCE: Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Posted on Oct 01, 2007
  • 27 Answers
SOURCE: HOTPOINT aquarious extra
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Posted on Feb 22, 2008
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
The quick wash takes over an hour any suggestions how to make it quicker?
The manual says wash number 5 takes 60 minutes the only shorter cycles are numbers 9 & 10 which take 55 minutes but they are cooler washes for wool and silk with a spin speed of 800rpm the number 5 has a spin speed of 1400rpm.
Apr 26, 2015 | Hotpoint Aquarius WDL540P White 60 cm...
Tip
Save on running costs.
Our clothes rarely get dirty, just need freshening really, and I got sick and tired of waiting almost 2 hours for the programme to stop.
I checked the times of different settings and found that programme J... silks.... only takes around 1 hour, washes at a higher water level and is around 40 degrees.
Now I never use any other programme. Dont over load your machine, dont put too many towels in as this programme is designed for 3kg, so check the weights till you are used to how your drum looks with different types of clothes etc.
We rarely need a heavy wash, and if I do I feel its better to do 2 light washes than do 1 protracted wash in the same water.
Im saving fuel and getting my washing done in half the time too.
sue
on Aug 18, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition washing machine door will not open after completing its full cycle
hi from the uk susan ? this is not uncommon and easily fixed if you are confident DIY ? and req's a little patience with a posi drive screwdriver if you want to save $$$$s on call out fee ? the problem is most probably the time delay switch which prevents door opening too soon after cycle/machine has finished and the light has gone off then door can be opened if you feel confident ? will help/instructions on how to rectify fault if you reply back ?
Apr 15, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint FEW 12
hi there i have had this problem before and found out it was due to to much weight in washing machine? or maybe your drumbelt may be loose which is connected to drum at the back on the inside? hope this helps
Nov 04, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
Oct 28, 2008 | Hotpoint First Edition FEW12 Front Load...
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WD129 Wash programme stuck
i am having the same problem with my widl126 washer.
ant help?
Apr 30, 2008 | Washing Machines
Hotpoint First Edition WMA20 Front Load Washer Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
