Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Replacement top rack for bosch SGS5002GB
The top rack of my now 10 year old dishwasher is coroding and i cant seem to find anywhere to buy a replacement any help appreciated
  • Bosch Master
  • 19,396 Answers
My seven year old Bosch dishwasher has broken down. Should I have it repaired or is it too old and buy a new one.
7 years is close to its lifespan more to the point bosch parts are very expensive in general it all really depends on whats wrong with it?
Oct 08, 2014 | Bosch SPV68L00GB Slimline 450 mm Silver...
I have an 8 year old (can't find model) dishwasher which was about 550 at the time so I think the top model. The cups / plates were coming out dirty so I did all the drain cleaning and ran finish dishwaher...
with your dishwasher bein the top model it is fitted with a diverter valve which directs the water to either the top or bottom spray arm. the way you are describing this it sound like that valve is faulty. depending on the model this can be a costly repair as you have to buy the full heating assembley to get the diverter. without knowing the model i cant be sure.........usually in this case its a mater of cutting your losses and buying a new dishwasher. stick with bosch or siemens all the same,
sorry i cant be of much more help
Feb 20, 2011 | Bosch Dishwashers
Coroding on the racks inside the dishwasher
poor quality, nothing to do about that, you can buy some paint that is water and heat resistant, sand down the rust and prime then paint it again, or complain if it is a new or new-ish washer (no more than 2-3 years)
Nov 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Should I buy a Bosch?
In my opinion, these do not live up to the Bosch name. They seem to come up on our radar here with "unusual" problems, and a lot of the questions posted go unanswered.
I replaced a beautiful stainless steel Kitchen Aid, after replacing the motor/impeller assembly because it was noisy, and the new one failed also. I bought a Samsung, and I like it. There a re several schools of thought about dishwashers, neither of them are very good, but here goes: One friend buys the brand name cheaper models. One buys only the higher end "best" types.
My best advice is to buy a brand with a high degree of reliability, and stay in the mid price range. The reason I say this is that the middle price range units generally have the better components of their "flagship" models, but don't have as many cycle choices, rack choices, etc.
GE, Whirlpool, (Samsung) are good brands. Frigidare is in there, too. I will never have another Kitchen Aid or a Maytag. I found them to be overpriced and unreliable, but this is just my opinion.
Best regards, --W/D--
Aug 11, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
May 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher
your filters need to be replaced. it's a 10 minutes work
May 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwashers
yes . you can go to thermador .com and order these parts.they will send them to you 2-7days
Apr 27, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Upper Rack
Contact Bosch and ask if there are any other rack configurations for this model. From memory I think there might be 1. I also remember that they made an insert to go into this particular top draw...check on that also Regards
Jul 13, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
323 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
