Is this connected to cable, sat or dsl box. If so your issue is with this external box not the tv. If the tuner in the set is used the do auto scan in setup menu.
Manufacturers normally have a backdoor, a four digit password to gain access into their operating software when the user changes the password settings.
Optoma people told me their default PASSWORD is usually 2468 or 8642. One of the two will work to unlock access to full menu options.
Remember to rate my answer as you can now enjoy your projectors 100+ inches :)
You might have it in the wrong picture size (zoom 1 or 2). Menu, picture, size ...
If this is not the case, you can go to the service menu and reduce the size of the viewing image. Turn off TV, press mute then 182, Turn on TV and this menu appears.
Good day, mckernannick;
To reset the TV first try unplugging for 2-3 minutes from wall. If that does not work try going into the service menu. Turn TV off, on remote push mute 182 power. You should see srv menu open options by flowing OSD directions. Make sure to note previous settings before making any adjustments. BE CAREFUL!!
Good luck, big IRISH.
Convergence ic need to be replaced. http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Phil..
to reset: Info>Menu>Mute>Power Button
make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings.
if you just want to reset freeview..
0 0 0 0
then press the colour buttons in sequence..
im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
i tell people all the time
if you get into the service menu and hit the wrong buttons
i wont know what you did to it
again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals
turn on the tv
push mute on the remote till mute goes out
hold down mute button and push menu on front of tv
hit menu again when the s comes up
hit 7 on remote and watch out
you just figured how to reconverge your tv
maybe not
