Question about Zanussi TC7114W Electric Dryer
No heat are there any inline fuses that can cause the heating unit of the dryer not to work as the dryer is blowing cold air
  • Anonymous Oct 14, 2008
    No heat is coming from trumble dryer. Can you tell me where the heater fuse is located. Taken top off of dryer and not apparent. Many Thanks.
  • 1,122 Answers
There is a main dryer fuse and a heater box fuse,the heater box fuse is the small bimetal fuse on the heater box,replace that and you should be ok,let me know how it goes-mike
Posted on Oct 12, 2008
My carrier hotel style heat/ac unit just blows cold in electric heat or heat pump setting
check the thermostat also check the inline fuse for the electric heat coil . check wires in control panel they tend to burn and last check to make sure reversing valve is changing over located by the compressor
Mar 05, 2015 | Carrier Heating & Cooling
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
Whirlpool Dryer (model lg5791xmw1) blows cold air. I switched out the igniter, dryer heated up and we put a load of laundry in. Checked in a half hour and dryer was running cold again. Thermal fuse?
no, cause thats a one shot deal, check your hi-limiy switch on the element case,they get weak from heat and can cause all kinds of (Under-Overheat) problems
Oct 15, 2009 | Dryers
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool dryer: blows but will not heat
If your dryer runs, but does not heat, click on the following link for some detailed advice on how to diagnose and determine the cause.
Most dryer heat problems are associated with clogged, or improperly installed ducting. It's much easier to rule out the external causes before inspecting the dryer interior. I hope you find this information helpful. If you need further assistance, please post back and let me know.
May 26, 2008 | Whirlpool LER5636P Electric Dryer
Zanussi TC7114W Electric Dryer Logo
194 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
