I own a PS50Q91HD Samsung plastma TV. The TV will not display on the PC setting while my NEC Versa P8310 PC is connected via the VGA cable. The TV tells me it is receiving no signal and yet my external PC monitor and a 50" Panasonic plasma is fine with the same VGA cable. This is pointing to a problem with the TV rather than the PC. Sometime I get a signal briefly for 1 second and then is simply cuts off with a message "No Signal" which is clearly wrong. Can you please advise me as to what I should do? Is this a Warrenty issue?
  • 8 Answers
SOURCE: Connecting PC to sony SXRD with RGB cable no display?
How are you connecting the PC to the TV (ie which input and what type of cable are you using?)
Posted on Aug 14, 2007
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
  • 300 Answers
SOURCE: I want to use plasma tv as external monitor
Your laptop is not set to enable the external video output.
Most likely, your laptop has a key that says "RGB/LCD" or something similar on it. This key cycles through the various video output options, enabling the laptop's LCD, the external RGB output, or both simultaneously. Most laptops require you to hold down the function key ("FN") when pressing the "RGB/LCD" key to cycle through the options.
Posted on Mar 04, 2008
SOURCE: Samsung LCD TV not receiving PC signal
This Samsung LA40C350 TV requires all pins are connected from D15 D15 VGA cable
Some cables what they sell in market dont have all wires connected. Only RGB, Grounds and Horizontal and Vertical sync but missing other connections
Samsung uses those other pins detect if PC is connected or not.
Next time you buy VGA cable, take multimeter with you and check that all pinns are connected through, before buying cable.
Best Reg: Eero
Posted on Jan 31, 2009
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from
My custom built PC will not connect to my TV via VGA cable ... > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Nec versa p8310
Check out Power Cable
Jan 18, 2014 | Computers & Internet
Open case screws
You should open your computer and reset the data cable which connects the motherboard and the screen. If it's not going to fix it, then you would need to get a technician to look at the motherboard and the LCD so that he can identify which part is causing the problem.
Jul 18, 2013 | NEC Computers & Internet
On my NEC Versa P8310 can I connect speakers into the headphone jack?
You'll need active speakers, (with an amplifier) not passive ones.
Jun 26, 2012 | NEC Versa Computers & Internet
Setting TV to display PC output via VGA cable.
there should be a source button on your remote press that till it changes to whatever its under on your tv on mine its under pc
good luck
Sep 20, 2009 | Samsung HCN436W 43" Rear Projection...
Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Mar 28, 2009 | Samsung LA40M81/BDX 40 in. LCD TV
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
try to download drivers for vista from could be reasons your old drivers if you installed ones.
Jan 11, 2009 | Computers & Internet
The internal bluetooth dongle on my nec versa p8310 is no longer recognised by vista, when i turn the bluetooth on it comes up with a window that says the usb device i have connnected is not recognised
If tried so many ways ti fix it but still it wont work, buy a usb dongle or card that supported by windows vista.or try to reinstall the driver for this device.the moment you bought this pc does it have vista already?
May 28, 2008 | NEC Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
