LG 1710 monitor has stopped displaying. On/off button just flashes green but no picture appears. Was working fine, no config changes made.
    Genius:
  • 1,605 Answers
Try unplug it from the outlet. wait 10 sec and replug it in.
the video driver might be corrupted.
go to lg wen site and download the lastest video driver software.
Posted on Oct 12, 2008
Screen flashed and stopped displaying widescreen
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
Oct 22, 2012 | LG W1934S-BN 19" Monitor
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Problem on LG Flatron ez T713SH crt monitor
i have the same thing, monitor display is dark and tick tick sound audible and thats all it do untill now..
Feb 15, 2010 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Green color missing from my LG 700s model
as you are electronics engineer so let us discuss technically.
as you are unable to see green colour means you might be seeing picture of magenta colour
as technically
red+blue = magenta
crt has got three cathodes
your two cathodes circuit is fine one ckt that is green cathode circuit is not working.
for that problem your will have to check
  • cable from computer to monitor
  • loose contact in crt base.
  • crt connector loose
  • voltage on green video output.
  • green video output transistor might be defective.or print loose.
  • circuit related to green video ckt
  • green video signal coming to green video ckt.
  • & finally crt defective (in rare case.)
  • hope this will help
  • good luck.
Oct 16, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
