Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Fax problem when sending a fax, a part pf the paper cames out complete black. the same fenomena happens when copying. thank you dalia
    Genius:
  • 2,120 Answers
You have a bad scanner assembly. Uneconomical to repair.
Posted on Oct 12, 2008
When I send a fax, the recipient gets all dark or black sheet. Thinking this was the recipients problem, I faxed again to a different fax number, same thing happened.
To fix the problem you have to check the scanner of your fax machine. It might not be functioning properly. Try to observe the fax machine while sending a document, look at the scanner section and see if the light of the scanner is turned on or lighted. If it's no longer lighted you have to replace it.
Nov 07, 2010 | Sharp UX 355L Plain Paper Thermal transfer...
Faxes I send are received as completely black
Scanner Failure. Make a copy on your machine. If it comes out black as well this means your scanner, the part that lights up and "scans" your document before sending it out has gone bad. Either the led's are not lighting up or the scanner board itself is bad. In any case the cost of repair is greater than the cost to replace these machines. You can buy a brand new plain paper fax these days for less than $100.
Good Luck and Thank You for using Fixya.
May 10, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Hope this is of some help.
Apr 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
BLACK PAPER
the scanning lamp is most likely not working\
here is the manual go to the maintenance section to see the scanning lamp
http://www.retrevo.com/s/brother+2820+fax++manual
Dec 18, 2007 | Brother IntelliFax-2820 Laser Fax
Recipient receives a black page
What happens when you make a copy on your machine?
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
