Question about Lands Phones
Nokia e51 wont turn on,notification light comes on but nothing on the screen
  • 7 more comments
  • regfixit Nov 13, 2008
    mine is the same after 10 months working Ok. Now light comes on and screen backlight, but just keeps going off again.
  • strongs Nov 13, 2008
    Nkia E 51 notification light remains on but cannot start phone
  • jahedpervez Nov 17, 2008
    I have the same problem. I left the phone on my desk and went to lunch. after I came back the phone was not working. I could not even turn it on. I've been using this phone for 2 months only.
    can you please help.
    thanks,
    Jahed
  • jj801 Nov 18, 2008
    only thing that has changed on my phone recently was the new version of gmail app. would this apply to any of the above posters as well?
  • Anonymous Nov 26, 2008
    i only bought the nokia E51 because i thought it wouldn't break down on me!
  • minyaloth Dec 17, 2008
    I also installed Gmail app.
  • Anonymous Jan 06, 2009
    i have same problem too, how can i fix it? i using e51 for 7-8 months
  • wlado Jan 13, 2009
    SAME PROBLEM, WITH TWO OF MY E51'S
    ONE AFTER 2 MONTHS, OTHER AFTER 6 +
    IT IS SUCH A SHAME, THEY WORKED PERFECTLY UNTIL THIS...
  • krrjch Mar 23, 2009
    The same satuation, is there anyone who used to fix it by self? and how?
Same here. the phone has not had any major problems for 10 months. I was on the phone when there were two separate incoming calls. I hang up and call the first one. Hang up once again, open the phone book to make a new call. The phone got stuck in the phone book, backlight became very strong. It was like this for 5-10 seconds, until i took the battery out. Now it won't "boot". The backlight, notification light and the ******** indicate that the phone turns on, but it doesn't continue from there.
I
Posted on Nov 18, 2008
  • jj801 Nov 21, 2008
    has everyone installed the latest gmail app, could that be the problem?
    or some other software?
Same problem here, sent it for repairs. got reply that "repair is not possible" so they sent me replacement. Got it today. Brand new and DOA. EXACTLY THE SAME PROBLEM - wouldn't turn on, just light, vibration and backlight then turns back off. It looks like Nokia QA is a joke. So I have to send it back to the service center. What a hassle...
Posted on Mar 04, 2009
  • alex-2009 Mar 05, 2009
    update: I got the replacement phone to boot. All I did was charge it with original Nokia charger instead of some aftermarket one I have been using before. Now the phone works. Go figure.
Sir how do I unlock my nokia e51
Hello. You can unlock your Nokia E51 safer and easier using unlock code, You can get the accurate unlock code for a Nokia E51 from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia E51 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E51.
3 - Compose #pw+CODE+1#.
4 - The Nokia E51 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E51 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E51
Sep 13, 2014 | Cell Phones
My nokia e51 hang up yesterday...i removed the battery and when i torn it on only notification light there is no display.....pls help me...
Hi and good day! will the problem of your phone is corrupted,and to solve it, reformat the phone or restore it into factory default, now after the reformat 's done please use the external memory of your phone and if possible only the contact number should be in your internal memory to avoid more problem later......
Aug 30, 2011 | Nokia E51 Smartphone
I have one Nokia e51. the problem is, when i turn on, the phone start but on the display i can't see nothing. i change the display with no result So the light from the display is working but the image...
does the phone still function normally otherwise? It sounds like what we call "the white screen of death." Basically, the wiring for the screen is shot but otherwise the phone is pefrectly fine. Very common on flip and slider phones.
Oct 06, 2010 | Cell Phones
My nokia screen is lighting up but with no picture.
my e51 screen also lighting . Some like as a> if a camera capture pic frm tv very near so there u see black line going up. My problem is same like that. .i also need solution
Jan 15, 2010 | Nokia E51 Cellular Phone
E51. when switched on, only shows Noika on white background, and will not respond. there is nothing else on the screen
This generally happens if you are using a hign volume SD card such as a 4 GB one and have a lot of files there. Then nokia when booted may try to scan all those files and takes a lot of time.
Remove your SD card and move most of insignificant data onto your computer using a card reader or the nokia usb cable. Then put the elmost-emptied SD card in your cel phone and try to reboot the phone.
Hope this helps.
Otherwise visit a authorized nokia service centre, they will upgrade the nokia's system.software and will fix application problems if any.
Nov 05, 2009 | Nokia E51 Cellular Phone
Describe your nokia E51 no light solution Problem
Hi, How to define Tones to Nokia e51, firmware version 300.34.56
Oct 01, 2009 | Nokia E51 Smartphone
Nokia e51 wont turns on only notification light always turns on when we attach battery in mobile pls help me retrieve out data over there in mobile
Hey veevec try to remove the carbon from battery and the copper which is present in the mobile where battery is touched
If there is no carbon
-> Is the battery fine (like no fatness , leakage or too much old or uncharged) * then change the battery
-> Is the mobile show a light on the screen * then try to format is by using
* + 3 + call + on/off button
And please reply me if my solution helped you please ....
Sep 14, 2009 | Nokia E51 Smartphone
My Nokia e51 wont send txt msg's, it used to be
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
Aug 27, 2009 | Nokia E51 Smartphone
Nokia e51 restart
i am forget our phone nokia E51 so how make to phone restart
Jul 04, 2009 | Nokia E51 Cellular Phone
Lands Phones Logo
3,613 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
