Question about Bosch Washing Machines
I have error F:16 on my washing machine.its an excell 1400S express
    Genius:
  • 1,239 Answers
HI Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Oct 12, 2008
My Bosch Excel 7 1400 express won't spin heavy bathmats with the result of me having to let them drip for a couple of days to lighten the weight! very inconvenient! have tried redistributing but doesnt...
Heavy Mats, Coats, Bedspreads etc....Your balance sensor will shut it down as you have heavy mats full of water they are very heavy. If it didn't your machine would self-destruct. You might try a commercial laundry as their machines are designed (bolted to the floor) to handle various heavier loads. Even those will shut down if it senses to heavy of a load though.
Hope I helped
Jan 09, 2018 | Bosch Washing Machines
Changed the element in my bosch washing machine and still trips the electric ,can i wash on a cold wash without tripping the electric.
In the washing machine your hot water supply comes from your water heater. The element that is tripping is part of your electrical so no you cannot expect a different result. You will have to fix the problem first before you wash.
Feb 19, 2015 | Bosch Washing Machines
F-21 on a Bosch 1400s- what does this mean
F21 Motor fault. Call customer service. (NOTE: if the motor brushes are worn, these can be replaced by a competent person).
May 20, 2012 | Washing Machines
Fisher and paykal 7.5 excellence
It is your motor controller board faulty.
Check the copper tracks for corrosion.
Mar 08, 2012 | Fisher and Paykel Washing Machines
Bosch EXXCEL 1400s. Clothes have a horrible damp smell when they come out of the washing machine. have clean and washed out all pipes but sill a damp smell inside machine. What is wrong with it? So bad...
yes,,,,,1 coup of soda crytal
1 coup of any vinegar
1 coup of diswasher salt
put it on 90 degree empty wash..........and see the result.....
my name is khan.
Apr 06, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Bosch exxcel 1400s express is the drum stainless steel
It is simple to tell what the drum is made of: if it is silvery metal-like finish, then it is stainless steel. It cannot be aluminum because the aluminum would not withstand the abrasive and detergent chemical action . It would also not be chrome or chrome finish.
If it is normal steel, it must be porcelain coated since porcelain can take the abuse necessary and also protect the steel from eroding. Porcelain will (of course) be white or grey paint-like finish. It could be a poly/pvc/plastic drum but this hopefully would be obvious and of course would also be white.
Many model come as an option of porcelain steel or stainless steel and the model number is the same except for one digit. I will assume your 's' digit stands for stainless, in either case, the silver metallic finish is the determining clue. Macgivor
Oct 11, 2009 | Bosch Exxcel WFX 145S Front Load Washer
I have a bosch exxcel 1400s washing machine and after about five minutes it trips the house electrics, can you help?
try disconnecting the Heater element, Both wires the plug back in and try..Good luck
Oct 09, 2009 | Washing Machines
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
My Bosch Exxcel 1400S Express (WFX148SGB) just doesn't spin anymore. Everything else seems to work fine?
Bummers. Sounds like the clutch is out. (If you can hear the motor spinning but not the drum, I'd say that's it. Especially if the machine has a number of years on it.)
I once looked into having a service man come fix a clutch. He said it would be cheaper to buy and new washing machine and have the old one hauled away.
Good luck.
Nov 12, 2008 | Bosch Washing Machines
Bosch excell 1200 express front loading washing machine
The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. If it's defective, it should be replaced. Good luck!
May 28, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
160 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
