Question about Amana Refrigerators
Our Amana side-by-side model SXD524VW (Belgium supplied and installed)stopped working. Lights still work. Some light noise (compressor?) can be heard. But it is warming up. Icleaned all out. It was really dirty after 8years operation :-( Is there a manual for this unit? There is a small black box at the front in the middle with a knob on it that will only permit turning clock-wise. What is it for?
  • v_eskes Oct 12, 2008
    Yes, by turning the little knob on the black box (siting front/botton/center behind the grill) did turn on something; I guess the de-froster as you said) on. The fridge and freezer section are getting colder and there is a hum; but the usual (quite substantial) operating noise can not be heard.
    After the big clean-up I powered up and the cold water dispenser did work again. And the water is getting colder.
    Should I just be patient?
  • 943 Answers
HI thanks for your question. that little black box is the defrost timer. turn that knob till fridge starts up. and replace the defrost timer. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 12, 2008
  • john gagnon
    john gagnon Oct 12, 2008
    Yes it will take 24 hrs be patient. thanks but that is a fix ya.
The lights are on but no cold air on both sides
sound like the compressor is not starting check the start relay this is the most common failure when not cooling
Dec 01, 2009 | Amana SXD524VW Side by Side Refrigerator
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
I have an Amana bottom freezer frigerator. The
Possibly a bad relay/overload or shorted run capacitor.If it was built between 2002 and 2005 it may be a bad compressor in which case you would want to check the warranty for possible coverage.
 the relay/overload and run capacitor plug right into the compressor on the left hand side.
 IF it isn't under warranty and the Oem part won't get it going pick up a 3in1 hard start for it they are easy to install and will get it working for you.
Sep 05, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana sxd524v fridge-freezer tripped out the power
Hi, you can check if there is a fanmotor on the condenser section and make sure that it is working. Second, you can try replacing the starter relay which you will find in the connection area of the compressor. If this does not work, I am afraid you would have to have the compressor replaced.
Mar 13, 2009 | Amana SXD524VW Side by Side Refrigerator
Amna cooling problems
first it sounds like a relay...
1 check if you have power to relay. ( use a multimeter)
2 check relay if it rattles its broke..
3 check if compresser is runing..
let me know I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Ice maker isn't working...
looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Ice maker isnt working...
just clearing this post from hte questions not answered list!
My amana scd23vbw
first do you have any heat from the compressor ? ( back bottom of the fridge) is the evaporator fan running. let me know and I can help..
Sep 05, 2007 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
149 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
