smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Buy a universal remote and in the packet is a list of code numbers for all TVs so look for make and away you go or look around the boot sale often find them here
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
You obviously don't have a menu button on the set itself. Unplug the unit and remove the back cover, this should expose the info you need unless it was placed on the outside and is now lost. Without TV model it will be difficult to get any helpful assistance. Good luck.
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just
press tv/video button to switch input source, let the tv in sleep mode.
