Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
How do I set up my wireless N router with a secure password?
  • kaikaneray Oct 12, 2008
    Link http://192.168.1.1 did not connect. I want to set up my pass word on my Belkin Wireless N router.
    Genius:
  • 1,913 Answers
Clik on this link http://192.168.1.1
them type uername admin and pasword also admin
if not success username blank and passowrd admin
Posted on Oct 12, 2008
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
Securing router from outside user.
Set wireless security to one of the options available. Also, set the router system ID, and change router login password, (record it somewhere, like on the actual router) change the wireless channel to 11 to avoid conflict with landline wireless handsets.
There are higher security settings, but wireless access password is pretty effective.
Oct 04, 2010 | NetGear Computers & Internet
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Set up a non wep password
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
4.Click Wireless Security and fill the sections
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
I need to secure my internet access.
to secure your internet connection, you need to put up a wireless security. to do that, you need to go to your router's configuration page by typing on your browser's address bar your gateway address.
when you do that, you should be able to see your router's config page. login using Admin as username and no password. click wireless:
select you wireless security mode:
lastly, specify your wireless password:
then save you settings. please note that WPA2 is just my preference.
to connect to your wireless network, specify on your wireless device your network name and password.
hope it helps.
Mar 12, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
I have usecured,i would like to have a secured
It is recommend to secure your Wireless network.
You can secure your Wireless network from the Router.
1. Connect the Router and the Computer using the Ethernet cable.
2. Open the Web Browser like Internet Explorer and go to the URL: http://192.168.1.1
This will take you to a popup box which asks you to enter a Username and Password. The username is either blank or "admin" and the default password is "admin".
4. Set the Wireless security from the Wireless -> Wireless Security option.
5. Save the settings.
6. Restart the Router.
Done.
Good Luck!!!!!!!
Oct 21, 2009 | Linksys Wireless-G WRT54G Router
Password settings
hullo
open up you Linksys user inaterface click on the wireless tab then security then go to the field called WPA SHARED KEY
then type your password to secure you wireless connection. Dont forget to save the settings.
Best of Luck.
Jul 01, 2008 | Dynamode RADSLC4WG Wireless Router...
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
