Question about Epson Stylus Photo R220 InkJet Printer
  • ANKITA621 Oct 14, 2008
    some time befor my printer R 230 in the head choke .than I replace a new head. I have use a ink supply system.the ink running and print procces is complet .
    BLANK PAPER PRINT after the print .new head is complet in other printer.what I need reset soft .
    some time befor my printer R 230 in the head choke .than I replace a new head. I have use a ink supply system.the ink running and print procces is complet . BLANK PAPER PRINT after the print .new head is complet in other printer.what I need reset soft .
    Problem Solver:
  • 14 Answers
Does this happen when you print from your computer or from the printer?
Usually when this happens you have a clogged print head. Pst for more info.
Posted on Oct 13, 2008
  • Allan Bautista Oct 21, 2008
    The printer is using Micro Piezo ink technology, a little vibrating quartz crystal is controlling the ink flow from the cartridges to the print head. This is not using the standard heat format, so of the heads are clogged in this way, youll have to remove the printhead and clean it manually. I've seen a great link that may help you out. Please visit this link:
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ... > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
May 20, 2010 | HP DeskJet 1280 InkJet Printer
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
