Question about Dell Latitude D600 Notebook
Stop error I am getting blue screen error message stop error .
  • John Hong
    John Hong May 11, 2010
    Need more information. The blue screen includes information that indicates the nature of the problem and sometimes the offending file. Please write down everything and post it.
    Genius:
  • 1,913 Answers
Okay
first of all heck yout
RAM is fixed properly in its slot then checksystem if u get same erros again.
then u need to bootable win xp recovery or source setup disk.
if u hve then simply boot your system with c d rom in firt boot devic then follow te steps.
then go to recovry console.then typein command prompt 'chkdsk /r'
then it rstrt then if u need to repir os then pres r then folow again ame procedure but this time pres enter and u have to go to repair win xp option.
Posted on Oct 12, 2008
Blue screen unable to restart windows10
A stop error (also called a "blue screen" error) can occur if a problem causes your PC to shut down or restart unexpectedly. When you experience this type of error, you won't be able to see things like the Start menu or the taskbar on the screen when your PC is turned on. Instead you might see a blue screen with a message that your PC ran into a problem and needs to restart.
If you see a stop error while you are upgrading to Windows 10, setup will automatically go back to your previous version of Windows.
If the error continues, try to fix it by removing software or hardware.
Sep 22, 2017 | Blue Computers & Internet
How to stop the blue screen of death
BSOD or so called, Blue of screen death occurs due to variety of reasons and once it do, you might have to force restart it to use your PC again. Old drivers, outdated windows, faulty hardware, degrading hard drive etc. are one of the top most reasons that causes bsod errors.
If you're not a pros or just a basic PC users, I'd recommend you to take your PC to any nearest computer repair shop and get it resolved there.
I'd glad to address if you've any further queries.
Feb 16, 2014 | Microsoft Windows 7 Home Premium 64BIT...
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
Sep 06, 2011 | Acer Extensa 4230 Notebook
I get blue screen when shutting down my windows 7
The blue screen of death is a serious problem. One ofthe causes could be overheating or could be because the graphics card isdamaged and doesn't work anymore. Try to use Registry cleaner and be freeof blue screen errors
Apr 25, 2011 | HP Pavilion g60-440US Notebook
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
I keep getting a blue screen appering as im trying to do things on here...why is that is it serious or no? what do i need to do to stop it grrrr!
What blue screen do you mean?
It is a stop message? With codes and a message saying "if this is the first time you seen this message, restart the computer" etc.
If this is the message you have to give the error code to know what is wrong with the computer.
If you have the code, you can search it up in microsoft knowledge base
http://support.microsoft.com/
Sep 17, 2010 | Cybertron (PCESXT1800ABA) PC Desktop
Error code OFOO:O75D error:OFOO:O244
Is this from a blue screen error ?
A "STOP" MESSAGE in white letters behind a blue background?
If it's a sata message (hard drive error message), this means that your harddrive is dead or about to die. Most likely its already dead, this error means also that the harddrive cant be read anymore.
Mar 05, 2010 | Dell Inspiron 1501 Notebook
Installed new hard drive
This is a complete step by step to solve your error: http://www.instructables.com/id/How-to-fix-a-STOP:-c000135-blue-screen./
I hope this solves your problem. If you need more help let me know and I'd be happy to help!
Shawn
Jan 14, 2009 | Dell E177FP LCD Monitor
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D600 Notebook Logo
70 people viewed this question
Alun Cox
