Question about Whirlpool AWM8103/1 Front Load Washer
Whirlpool AWm8103/3 We select programme ie daily load and the machine clicks to register setting then we press start and the door open light comes on flashing with the start button although the door is firmly shut . Can you hepl please ? many Thanks Ian
I had the same problem and found that the brushes on the motor had worn out. I replaced them and now all is well. They cost between £30 and £40 to replace and it's a very straight forward job. My only problem was excessive sparking from the new brushes until they bedded in. I simply ran the spin program at 400rpm a few times until the sparking disappeared.
As always, be careful around electrics and if your not sure get a pro to help
Posted on Nov 28, 2008
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Hi, I have a Hotpoint wm53w first edition 1200 and the door light does not come on when the door is shut. When I switch it on and set a programme, the amchine sometimes does not start, the door light
Generally the problem lies with a faulty door interlock switch rather than a programmer fault. These are can be purchased easily but don't be fooled into buying cheap alternatives, and if you are a competant diy person no problem to fit.
Feb 27, 2014 | Hotpoint BWM12 Front Load Washer
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Wont do anything
Maybe door latch adjustment. hold door in at latch and see if it will work
Jan 04, 2008 | Whirlpool AWM8123 Front Load Washer
Doesn't start
Is there power in your wall socket? Does any light on the machine come on? Check your washer-plug. The fuse inside the plug could be defective......
Nov 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM8103/1 Front Load Washer Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal De
