Question about Garden
Weedeater or trimmer
I have a weedeater featherlight plus...the engine quit running.. ..hard to start like of power..so I pulled the plate to the pump off.. pump was very stiff so I replaced it..weed eater will idel..but will only contune to run if held wide open..engine surges medium,,to .. light notice more when the weedeater. tilted up or down,,when held evenly it gangs power..ive been through the CARB> to or three times I see nothing wrong with,,CARB..am I over looking something..NOTE when you try to sped engine. trys to kill out..BUT if chok is closed 3/4 way the engine will pick up more power..is my carb still missed uo.or what..thank you My emil is ineedusexy@yahoo.com
  • 48 Answers
Sounds like the carb is still not right or the unit is low on compression - you need 90 lbs min
Posted on Oct 17, 2008
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I got a 2 cyl featherlight weedeater I put a new
You need to be sure you're getting fuel and spark before you do anything else.
Sep 09, 2014 | Garden
I put a new spark plug and fuel limes and cleaned
You didn't say if it had spark or not?
I changed the prime bulb spark plug and fuel lines
Ok, so you have fuel, do you have spark?
Weedeater starts but won't keep running
Grow a third arm or have someone follow you pumping while you trim :-).
The fuel pump is part of the carburetor body. You could disassemble it and see if something is stuck in one of the flappers that make up the pump or it may be broken and need a replacement. It's just a thin plastic piece in there that makes it pump using engine vacuum pulses to drive it.
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Does poulan featherlite weedeater have a compression releif valve
It barely has a motor. No it has no need for compression relief.
Aug 11, 2012 | Poulan Featherlite Plus Gas Trimmer
I have a weedeater brand hedge trimmers 18 inches long. I rebuilt the carb and replaced fuel lines and filter. The unit ran fine until the last two times that I have tried to use it. It will run and...
have you checked the fuel plate thats in the bottom of carb? they tend to dry up and because rubber the 2 stroke fuel makes it dry and shrink, then it no longer pumps fuen into cylinder
Mar 01, 2011 | Weedeater Gas Powered Hedgetrimmer...
Ryobi trimmer plus won't start. No sound at all
if it pulls super easy and it doesnt sound like the engine is even rotating when you pull it it is your pull cord assembly . basically its a giant ratchet my advise is just get a used one of a blown up weedeater it would be cheaper
May 12, 2010 | Garden
My weedeater want start change spark plug
I would have a cylinder compression done on the engine before spending any more money. It may be below 100 psi and will not run. Plus if your fuel mixture is over 30 days old I would mix up some fresh fuel mixture.
Or the diaphragm in the carburetor has become stiff and is not pumping any fuel.
Good Day.
Oct 12, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Featherlight plus weedeater, where does the second gas tube go?
On a two-stroke engine, the second line is a pressure line.. it is actually running back to the tank and helps pressurize the tank to feed on the other line...there should be a second hole in the tank .
Jul 23, 2009 | Garden
Garden Logo
835 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
