Question about Cameras
Canon Ixus70 "Lens error" lens
Canon Ixus70 "Lens error" lens will not withdraw. Keep trying and it makes a grinding sound but nothihg happens, then it says "lens error, restart camera" and turns itself off. (Does restart camera mean turn on again?) Can't find receipt at moment, but is under 1 year old.Would warranty caver this sort of problem? Have been travelling. ?sand? Should I take it to repair place and/or claim travel insurance? Or can you suggest it try something else. Have given it a shake, blown on it, taken battery out etc!! Thanks
  • squid123 Oct 12, 2008
    Can't access these pages at the moment to read the answers. Comes up as page no available. Can you check for me please!
    Thanks for the comment. I will have a go despite no receipt. It definitely hasn't been dropped, so i'm not happy!!
  • 118 Answers
Your warranty should cover this problem.
Take this to the dealer with the recipt and as for a replacement.
It will probably get sent away to be fixed.
It may be difficult without a recipt, but if you email/call canon, they are obliged by the consumer garuntees act (at least they would be here in NZ) to help.
The problem sounds like the motor which makes the lens contract is damaged. This shoulkd be claimed under wararnty.
I dont think sand could be a cause, more likely a drop, but attempt to claim it as they can only say no.
if all else is lost, look at paying for it to get repaired, but it would probably be easier to buy a replacement off ebay.
Thanks
Ben
Posted on Oct 12, 2008
    Brigadier General:
  • 6,966 Answers
Apparently this is a common and known issue. Similar concerns has been addressed on this site and the solutions posted here, here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 12, 2008
    My apologies, for some reason the pages linked erroneously, pls try:
    • http://www.fixya.com/support/t1060232-ca...
    • http://www.fixya.com/support/t620533-elu...
    • http://www.fixya.com/support/t110455-zoo...
    Cheers.
My camera doesnt want to open the lens..i cant use it anymore.
Sound like a problem with the lens stuck; is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Jun 02, 2011 | Nikon Cameras
My camera say lens error 111000
Your lens problem is common defective. It need lens unit replacement or just repairable.
Try just some basic things first-just to make sure it's actually the lens that's broken. Replace the batteries with fresh ones. Failing that, replace the memory card.
Keep us updated.
May 31, 2011 | Kodak Easyshare C813 Digital Camera
Canon g10 lens error.. lens fully extended then won't take a photo.. then the lens error appeared
Keep us updated.
May 26, 2011 | Canon PowerShot G10 Digital Camera
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
E18 error w/sound effects!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 18, 2009 | Canon PowerShot A95 Digital Camera
Camera was dropped-- "Lens error-restart camera" message
If it is still under warranty , please repair it.
If it is out of warranty. Try to get a quote, it the quote is more than 50% of original value , forget it.
For digital camera's they die like flies. New ones are better and cheaper anyway.
Mar 22, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Lens error
Press the power button on and hold it down while extending and twisting the zoom lens......
Oct 03, 2008 | Canon IXUS V2 Digital Camera
Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2007 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon SD600 Lens error
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon IXUS V2 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
