Question about Shinco SDP-1850 Portable DVD Player
Frozen controls on dvd player
When initially setting up the player I inadvertantly chose shinese as the osd language. In trying to get back to English, i did something? which froze the controls. the machine will not repond to remote or onboard controls and I cannot get back to the setup screen. The screen only displays colored vertical lines. Is there a way to restore factory settings so I can start over again corefully? get back to original setting . The product is a Shinco SDP-1280 but I could not find that number on your valid product list
philipp
  • 217 Answers
SOURCE: shinco SDP-1731A 7" dvd player
How about cleaning using compressed air( it looks like an aerosol paint can)? Cleaning using cotton buds will only clean the outer side of lens, compressed air in can will clean the inner side of the lens. its like cleaning you computer keyboard, ( actually compressed air in can are used to clean the keyboards). A 30psi pressure of clean air is enough to wipe the dirt out of dvd lenses.
Posted on Aug 23, 2007
vortash
  • 431 Answers
SOURCE: Shinco Portable DVD SDP-1731A - Sound not working.
I have had a couple of these with the same problem , and in 2 out of the three cases the cure was the same .. Earphone socket fault ?
Ear phone sockets are designed to dissconect the speakers on insertion but with the constant use and pulling they get on a mobile system they sometimes lock open and do not reconnect the speakers you could check that ..
The other one I had was diffrent that one the sound output chip was faulty and had to be replaced as did the speaker output capacitors , one had failed causing the chip to overheat .. hope this helps Regards Vortash
Posted on May 12, 2009
  • 8457 Answers
SOURCE: Looking for replacement connection from Battery
Tries websites like Amazon.com,Ebay.com to buy many portable dvd players accessories.
Posted on Jun 21, 2010
muntejaya
  • 10421 Answers
SOURCE: Shinco SDP-1731A wont play NTSC region DVD'd. OIs
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_rctg67
Posted on Feb 27, 2011
I can't figure how to get the closed captions to work. I am nearly deaf.
Press SETUP
Get to LANGUAGE SETUP PAGE
You can select OSD language, and select audio/subtitle/menu
language of DVD discs if available. Also you can select font type for mpeg4 subtitle
Remember you get SUB-TITLE only if your DVD supports it meaning contains it at the first place.
Sylvania SDVD9020 User Manual Setup Menu Setting
Feb 19, 2016 | Sylvania SDVD9000 Portable DVD Player
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
When I played the file on the computer it was in English, when I burned it and played it on the player it was French. Is there a way to toggle language with remote control?
This is a movie u burn with a computer duplication software correct one to one exact coppy?Yes,go to the movie main menu should have languages like French,Spanish,English.Should able used ur DVD remote controller to chose and pick the language u wanted.
Aug 08, 2011 | Magnavox NB500MG1F Player
Have inadvertantly changed from english to foreign language...how can I return to english
Go to Start- Control Pannel--------Region And Language ----- now under Region and Language Click Keyboards and Language-----Change Keyboards--------- under Change keyboards you Click ADD------- now chose ever language you want and restart the computer.
Jul 09, 2011 | Computers & Internet
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
How can I unlock Sharp DV-SL2200W
To unlock your DV-SL2200W player follow the below instruction.
1. Switch the player on without disc
2. Using the remote control press "HOME MENU"
3. Select "INITIAL SETTING"
4. Select "OPTION" on screen
5. Press "OSD" button
6. Press buttons, 3,5,7,0
7. The player will automatically shut down
8. Switch the player back on
Now you player will be Multi Region.
Sep 05, 2009 | Sharp DV-SL2200W Player
I cannot change the language settings on the dvd
switch on your dvd player and with the remote press the setup button. go to the general page and it will give you the option to set the OSD language. you can set it there in english ^_^
Mar 29, 2009 | Televison & Video
DVD player wont show on screen
You can reset the dvd player back to the original settings by doing the following: While stopped, press and hold [QUICK OSD] [DVD-S29] or [ADVANCED DISC REVIEW] [DVD-S26] and [PAUSE] on the unit and then also press and hold [< OPEN/CLOSE] on the unit until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jun 26, 2007 | Panasonic DVD-S29 DVD Player
Shinco SDP-1850 Portable DVD Player Logo
Top Shinco Televison & Video Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
