Question about BenQ Joybook 3000-01 Notebook
Wont turn on at
My benq s31v will not start up. on turn on it starts to make noises as if starting up but then stops quickly. no light on screen at all. power button only lights up. any ides how to fix.
    Scholar:
  • 123 Answers
This is common when the charger is not working anymore and the battery is almost dead. It has just a few seconds of life.
Verify that the charger is working. Plug it in and see if any of the light come one in the front then unplug. If not lights then it isn't charging. Even if the light comes on, you need a multimeter (12.00 at walmart) and put it in and check for the 24/28Vdc (read what the output is on the bottom of the power cord).
Posted on Apr 29, 2009
Engine turns over, car won't start
Engine Cranks But Wont Start - Professional Mechanics ...
www.2carpros.com/articles/car-cranks-but-wont-startJul 15, 2015 - Step 1 - A fuel pump operation failure will cause the engine to not startdue to ... The power distribution center of a vehicle houses fuses which .... Works atCVS ... I have a 1991 ford f150 the motor turn over fine but it won't start.
Car won't start - check VSC light - Club Lexus Forums
www.clublexus.com/.../is.../519132-car-won-t-start-check-vsc-light.html
Aug 13, 2010 - Car won't start - check VSC light IS - 2nd Gen (2006-2013) ... Carmakes an exaggerated version of the engine startup noise. Hard to describe the noise, but the one that sounds like .... It stopped accelerating, the VSC check & check enginelights came on. I immediately pulled over. Waited a few minutes.
Nov 22, 2015 | Cars & Trucks
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Murano wont start
Program your fob or your starter
Apr 20, 2013 | 2009 Nissan Murano SL
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
I have a benq joybook 5100 and xp home edition.I formatted my notebook.I want reinstall from Home edition CD.But windows 98 starting... " 98 start file comes and "quick restore" a window comes."english" to...
you can use either two system. just follow  the screen when installing it... put it on the other partition (drive)....
when starting you can select xp or 98.....
Jan 28, 2010 | BenQ Joybook 5100 Notebook
Xp drivers
Hi
The website below will help you, you may need to register before you can you download
.driverguide.com/
Mar 27, 2009 | BenQ Joybook S33 Notebook
2002 chevy malibu won't start
Does the starter make any noise or click when you turn the key to start? If it does not, chk. battery could be bad, and battery cables could be loose or corroded. If there good and clean and battery is good try tapping starter see if it will turn and start if it does or still clicks starter bad. It could be ignition switch if it does nothing at all, but if it clicks most likely its starter.
Feb 16, 2009 | 2002 Chevrolet Malibu
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
BenQ Joybook 3000-01 Notebook Logo
281 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
