Question about Canon Office Equipment & Supplies
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the fax function the phone line will not disconnect after a call is placed unless the plug is removed and then reconnect to the "line in" port. I have checked all the fax setup entries and every thing seems ok. Do you have any Ideas? Thanks, Stu Bardach
  • 2 more comments
  • sailstu Oct 12, 2008
    Hi Findmeifucan,
    I have removed both the line from the wall to the copier and the copier to the phone several times. I have also tried replacing both lines. When I depress the hook button on the copier I get a dial tone but the line wont disconnect when I press the hook button again. The line stays open and I get a message from the phone company saying if you would like to make a call please hang up and try again. The only way to get a new dial tone is to unplug the line to the copier from the wall and then reconnect it. However, then the problem repeats.
    The lines are not crossed as I am able to get a dial tone once I go through the disconnect and reconnect procedure. Hopefully you have some new idea.
    Thanks,
    Stu
  • sailstu Oct 13, 2008
    Does anyone else have a suggestion for a fix?
    Maybe I have not been clear. There is only one phone line coming in from the wall. The problem is that the phone engages when the hook key is pressed but will not disengage when the hook key is pressed again. The line will only disengage when the phone line is unplugged from L in jack at the rear of the printer. Has anyone seen and have a fix?
    The lines are connected as follows:
    1) Single phone line wall jack to printer L line in port.
    2) Phone out port from printer to line in port on answering machine.
    3) Phone line set to Tone
    4) Fax set to answering machine mode.
  • Canon Master
  • 1,879 Answers
Just want to make sure : on it's own, the copier fax functions works normally ? and is it also the same with the answering machine ? probably yes.
after activating teh phone line from the copier, teh answering machine gets teh signal too and it doesn't know when to hang-up.
check the answering machine for an option to drop the line after if there's no activity for a minute.
Posted on Oct 13, 2008
    Sergeant:
  • 352 Answers
Hi stu, this can't hurt to try, it updates all drive
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
rs in an all in one, including the fax drivers.
    Master:
  • 538 Answers
Is that fax line have a call waiting feature, by chance..does it work with a phone device..may not be the printer at all..
  • A Womans Computer Man
    A Womans Computer Man Oct 13, 2008
    ok..sounds like line noise to me..you may wish to get a donut that will help relieve that glitch on the phone line..
    hate to tell you this..it could just as easily be the phone line.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Can you tell us how you connect phone and the printer? You have any connection box?
Give a try by replacing it.
Are you using touchtone answering machine/ phone?
    Genius:
  • 1,124 Answers
The answering machine must be connected to the device for the fax to monitor the line for fax tones.
  1. Connect a line cord from the telephone wall jack to the [L] jack on the device.? The [L] jack is indicated in the magnified view by the red arrow.
  2. Connect a line cord from the extension telephone port on the device to the answering machine.? The extension telephone port is indicated in the maginified view by the blue arrow
The number being dialed is not the number to which the fax is connected. This will occur if there are multiple lines and telephone jacks in the same location. Or if the telephone jack is wired for two lines. For example, line one is to be used for voice calls and line two is to receive faxes. If there are multiple lines and jacks in the same location, try a different jack. If the telephone jack is wired for two lines, connect a telehone line splitter (adapter) to separate lines one and two. Or, contact a telephone technician to rewire the jack so that line two is on a separate telephone jack.
  1. Disconnect the fax machine from the telephone wall jack.
  2. Connect a known functioning single-line telephone directly to the telephone wall jack.
  3. Dial the fax number to see if the phone in the home will ring. If the telephone rings, reconnect the fax to the wall jack and request a test fax is sent.
  4. If the telephone in the home does not ring, obtain a telephone line splitter (adapter) to separate lines one and two.
    Note: Not all adapters separate telephone lines. Some adapters merely provide an extension telephone jack.
  5. Connect the fax to the line 2 port on the adapter or the preferred line.
  6. Request someone send a test fax.
  7. Connect a single-line telephone to the line 1 port on the adapter or the open port on the adapter.
Posted on Oct 12, 2008
    Genius:
  • 1,550 Answers
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
How do I connect two computers to my Canon MX3520 printer?
in the control panel where you see add a printer, you have to add the printer to each computer then click on the share printer box
Jan 09, 2017 | Canon Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Canon mg6150 printer too much pink in photo's when printed
Please calibrate the printer using Canon software.
Mar 08, 2014 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
181 people viewed this question
old marine
old marine
