Question about RCA P46924 46" Rear Projection Television
Alignment how do I realign my projectors
The pojection color is out of line. menu doesn't show how to do it. it used to but does not now
Posted on Oct 30, 2008
Realign blades
What kind of shaver let's you re-align the blades? Replace I understand, but re-align? Please let us know what model you have...
Oct 26, 2014 | Health & Beauty
Ghosting Image
hi!!!
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
Sep 21, 2008 | Philips ProScreen 4750 Impact Multimedia...
The 3 colours are off center not aligned properly, the convergence is off and idk how to fix
replace convergence ICs but dont try to realign befor replacing as it will align wrong and its a very long process to realign, if it is a very old unit check out ebay as they are going cheap second hand mite be cheaper to buy another
May 07, 2010 | Sony KP-53V85 53" Rear Projection...
My sony projector works great but there seems to be some green coming in on the screen..i played with the setting but no results..Are their any trim pots for the red,blue,green lcd panels?
if you reset the settings to factory default and swaped out cables, then the oly thing left to do would be to realign the lcd panels. unfortunately, only sharp service centers can do this easily. they have a tool specifically made for lcd panrl alignments on sharp projectors. you could try av solutions in ny. the'yr pretty good. www.avsolutionsny.com
Dec 04, 2009 | Sony VPL HS10 Multimedia Projector
Epson 3lcd projector projects pink stripes
reset the settings to factory default. the signal does not match.
Nov 10, 2009 | Epson - PowerLite S1+ Multimedia Projector
The colour keeps going to more blue and the screen is fuzzy?
you should be able to align your projectors through the setup menus. you will have to align two colors, usually red and green to stop the fuzziness and you should look at the tint selection in the menus for the blue color if the realignment does not fix it as well.
I could not locate the manual on the Hitachi website.
Oct 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Double image, fuzzy picture
The problem was caused by poor projector alignment. Alignment was off because we recently moved the TV from a friends house.
This particular set allowed me to realign the projectors with the remote control from a setting in the TV's menu. It was as simple as opening the menu item then aligning the cross-hairs with the remotes cursor. There are 3 projectors, one for each color. One is fixed and the other two are movable. They need to be perfectly aimed in order to get a clear, properly colored image.
When you find yourself with an electronic device and no operators manual it pays to spend the time and effort to download it from the internet.
Problem solved, thanks
C L Ganske.
Apr 11, 2009 | Televison & Video
Blurry and bent screen
It sounds like you have moved the mirror, turn it on and try to see if you can realign it. KEPP YOUR FACE OUT OF THE LIGHT PATH.
Marc Engineer
Dec 06, 2008 | Sony KP-57WS500 57" Rear Projection...
Proxima projector A10
reset the settings to factory default. if it's still off, you'll need to send it in to an infocus service center. they'll have to realign the lcd panels or replace the optical engine.
Nov 21, 2007 | InFocus Proxima Impression A10 Multimedia...
Service mode
there is no convergence. try resetting the settings to factory default through the menu. if you have a dlp, the colorwheel and dmd chip are set. if you have an lcd, the lcd panels are locked down. if they are off, you'll need to go inside and realign them physically. but that's chore, because you have to plug it in, turn it on, see which way you need to go, power down, unplug, remove the top cas, remove the main board, adjust, tighten, replace the board, replace the top, plug in, power up, check the image, and do this as manny times as necessary. leave it to the service centers.
Mar 11, 2007 | Boxlight -670k Multimedia Projector
RCA P46924 46" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
