Question about NetGear RangeMax WPN824 Router
Net gear router won't install properly and will not let me use the internet
Does anyone know if there is a trick to getting the router to work, if I disconnect it modem works fine if I connect it websites can't be found.
    Brigadier General:
  • 6,966 Answers
You may want to try:
  • If both your router and modem have DHCP features enabled, disable the one in the modem;
  • manually set the Internet/WAN IP add of the router to follow the IP add of the modem;
  • manually set the default gateway of the Internet/WAN side of the router to use the IP add of the modem;
  • set the PCs connected to the router to automatically obtain IP adds.
  • verify that the PCs uses as their default gateway the IP add of the router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 12, 2008
I want to connect my Xbox 1 to the Internet so it can work but don't know how!? My only source of Internet is my sprint router net gear air card! Does anyone know how to connect an Xbox 1 to a sprint...
Yes, it should be easy to connect your Xbox One to the internet.
Assuming your Netgear router is wi-fi capable, go to Network settings on the Xbox One. This will display Network status - wireless settings - etc. Follow the setup procedure here:
Network settings on Xbox One
Feb 26, 2014 | Computers & Internet
Using a notebook PC's internet signal to go online with a PS3
look for a net gear router and dont bother buying a N+ its not worth it for starters its a scam it even says on the news so get a net gear G wireless router and its roughly £35-50 but its worth it, buy it from amazon or from a argos or littlewoods site. im hopefully going to get wireless in christmas time, so ill hopefully add you some time soon you can contact me thru here for my name if i do get online
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
The other day i plugged a net gear adapter in thinking it would connect me to the network at work, but i realized it was just a wireless adapter, and my computer is already equipped with wireless. Anyway,...
First, I would go to the control panel (start, control panel; or start, settings, control panel). Then got to Add/Remove Programs. Scroll down the list until you find what looks like netgear software and try uninstalling there.
If that does not work or you can't find it in the list, you could try inserting the install cd again. Check to see if there is an unistall option, and perform an uninstall. Or, if not, then try installing it completely, then uninstalling it via CD.
Mar 18, 2009 | Computers & Internet
ROUTER PROBLEM
Try setting the XBOX ip settings to static, see instructions here
http://www.howtofixanything.co.uk/howto-282.html
Feb 05, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I have been using Netgear for approximately 6 months. Two weeks ago, all Internet Service was stopped for both my HP Windows Vista desktop and Acer Aspire 9300 Windows XP laptop. Think either Net Gear or...
Try to use your laptop in the other wifi connection if it's work the problem is your router wifi configuration. But if cannot work try to check in device manager if your wifi device is working properly. in the RUN type DEVMGMT.MSC and look for your wifi device there if there is a ? mark it's mean that there is a complex configuration in the wifi. remove the wifi device in restart your computer the windows automatic detect the device in install it. try to connect if it is work but if still not work check for the ip and gateway configuration in the wifi setup.
Apr 25, 2008 | Computers & Internet
Linksys Wireless-G 2.4Ghz Broadband Router Problem
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Feb 28, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
NetGear RangeMax WPN824 Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
