Question about GE Spacemaker JVM1640SJ Microwave Oven
Exhaust fan does not run
We just purchased a manufactured home that has the GE Spacemaker over the range microwave (JVM1630WB 002) and the exhaust fan does not run. It appear that everything else is working OK. Is this likely to be the PC board or the fan motor? Is it worth the cost of repairing it or should I just go ahead and replace it?
  • 2 more comments
  • burtonp Oct 16, 2008
    I do not know what size the exhaust is. It is vented throught he side wall and the vent looks to be about 12" wide.
    The lights do work on the unit and when you press the touch pad for the fan you hear nothing.
    Does this information help?
  • edkelly47 May 11, 2010
    what size exhaust is required, 4" or 6"
  • William Miller
    William Miller May 11, 2010
    Are the hood lights working?
    Do you hear a faint "click" when you press the vent fan pad?
  • Anonymous Mar 22, 2014
    Exhaust fan runs continuously. Have tried unplugging the unit
  • GE Master
  • 9,098 Answers
Yes, It sounds like the control board needs to be repaired.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week in most cases.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 17, 2008
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker Microwave DE68-40861A that has a built in range vent. The fan motor blows just fine, but there is no airflow. Apparently this was installed improperly. What would be blocking the...
take microwave down. There is 1 screw on the back that hold fan in. Pull screw out and the fan will lift out. Roll fan so that opening of fins faces to the front. set it back in put screw back in and remount microwave.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our Microvave oven build in over the range , Model # JVM1630WB is not heating anymore; the Microvave also makes an unusual noice. Please help with a solution. Do you recommend repair or a complete new...
Hi, Most microwave problems are not worth repairing...espec. one like this that sounds like it will be rather expensive to repair...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
While replacing one of the lights on the underside of the GE Spacemaker JVM1631WB 002 the bulb came loose from the socket and a loud pop blew out the other light. Now neither light works. All other...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Aug 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Humming ge sapcesaver microwave
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear. Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
345 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
