Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Oct 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water Leak Whirlpool Washing Machine Ultimate Care II LSQ9564J Top Load Water is leaking from bottom of washer - I filled up and tipped and water is dripping from pump ( part # 3363394 ) or hoses that attach to it but hoses and connections look good. Machine is 3-4 years old and used heavily for family of 6 - 3-4 Loads per day, everyday. How do I know if pump is leaking or cracked ? Could it be Tub Ring Seal ( 3976308 ) ? Should I just replace all hoses, clamps and see if leak continues ?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Nov 05, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
Helped
120876
Points
632
Is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Does not take water ,hot or cold
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Dose it has a filter and my hot water wont work only cold
heatman101
Washer does not fill with hot water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
My whirlpool ultimate care II is leaking water.
Use the video to see how to disassemble the washer to check for the source of the leak.
The leak is probably in the drain pump.
http://appliancejunk.com/forums/index.php?topic=5191.0
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
Can a bubble in the cold water fill hose cause
No, not that I have ever seen. If it does it will be the first I have seen and I have worked on many of them.
Please rate solution
Water is leaking from my wash machine
Ifit is from the front middle of the unit that is the water pump they are made of plastic and can start to leak best was to check is to tip the unit back a little and look
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
