Question about Kenwood KM800 Major Classic Stand Mixer
Need mixer shaft and gearbox - Kenwood KM800 Major Classic Stand Mixer
  • 99 Answers
This part is avaliable from us £68.00 +p&p
Posted on Oct 12, 2008
My mixer simply does not turn on and has an oil leak. How do I troubleshoot and fix?
Check for circuits through cable, switch and field windings. While checking the fields check that your carbon brushes aren't worn out. Remove the chrome drip ring from around the planetary (it just taps off) and clean the oil out. If you are feeling brave you can knock the planetary pin out that connects it to the driving shaft and lever the planetary off. Wipe the excess oil out of there remembering that the gear does need a smear of grease remaining. The oil is the grease in the gearbox breaking down with age, eventually you will need to open the gearbox, remove the old grease & replace it. The oil itself is harmless as the grease is food grade so it's not a petroleum product.
Jan 01, 2016 | KitchenAid K45SS Classic Stand Mixer
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Oil leaking from the attachment head
The grease leaking out of the KitchenAid mixer can be a common problem. Here is the cause, and how to fix it, and prevent this issue from happening in the future.
The KitchenAid mixers use a Benalene 930-2 grease inside of them. It is a dark, thick grease that can break down and leak out of the mixer. The grease is a non-toxic vegetable based grease, basically it is a food grade grease. Over time, or if you do not use your mixer often the grease can break down, so it would appear that there is oil leaking from the mixer. It is most common for it to leak from the beater shaft (agitator shaft) and from the drip ring.
What you need to do is take the mixer apart, clean out all of the old grease, replace it with about 6 ounces of new food grade grease ( It is also recommended that your replace the o-ring on the center shaft ( and the gearbox gasket (
To prevent the grease from breaking down in the future if you do not use the mixer very often, it is recommended that you pull the mixer out and run it for about 2 minutes every 3-4 weeks, this should stop the grease from breaking down as quickly.
Please let me know if you have any questions.
This applies to mixer models, K45, K45SS, KSM75, KSM90, KSM103, KSM110, KSM150, KSM151, KSM152, K5, K5A, K5SS, KSM5, KSM50P, KP50 AND KPM5
Thank you,
Customer Service
Apr 15, 2013 | KitchenAid KSM150PSGR - Artisan Series...
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
Utencils touch the bottem of bowl
it sounds like the planetary has gotten loose and dropped down. Check out this parts list so you can see how it is put together.
Try pushing up on the shaft which holds the mixing attachments. It should not move more than 1/32 inch - if it does then something inside the gearhead is worn and you will have to take it apart. If the whole planetary moves up and down then something deeper in the gearbox is worn.
To take it apart lay it on its side and carefully pry the chrome ring off. Now drive out the pin that goes thru the planetary and the shaft. Now pull the whole planetary off its shaft. Remove the six screws underneath plus the other screws you can see from the bottom of the gearbox - there are 4 more. Now carefully pull the top half of the gearbox from the bottom half, which will expose the gears. Examine for worn parts and replace the necessary ones.
Apr 12, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Has very loud gear noise, too much play in worm drive?
Here is the breakdown of your gearbox. Pull it apart by removing the cover of the unit and checking for play from the motor shaft thru to the beater shaft. It will more than likely be one of the plastic gears.
Mar 23, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
I have oil leaking from the beater shaft. a lot
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at
Dec 23, 2009 | Hobart D300 Stand Mixer
The blades in my Kenwood mixer keep slipping out of the housing. I can't see anything wrong with the blades so it must be the fitting inside.
Yes! we can supply this part£ 15.00 + p&p shaft size 14mm,If yours is differant size it would be new gearbox.(vertical drive shaft)
Jul 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
53 people viewed this question
Top Kenwood Food Mixers Experts
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
