Question about Lexmark Office Equipment & Supplies
My all in one printer won't print the initial alignment page
  • 535 Answers
Remove & reinstall printer driver & try to print
Posted on Oct 12, 2008
Scan not a good quality
If you can adjust the printer's settings at either the printer's interface or on your computer - go into 'settings'. You'll want to look for something like initial setup or print quality - or possibly print report and this option may come up - but you should try and print an automatically generated alignment page - once printed, they're scanned and adjustments are made by the printer to produce the best images it's capable of. There are going to be other 'tools' such as clean ink cartridges, etc. - good to periodically perform all of those actions - but that 'alignment' page and scanning it should really help you out. All the best.
Jan 25, 2016 | Epson Office Equipment & Supplies
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
I recently replaced my printer cartridges in my hp psc 2210 all-in-one and it printed fine the first day. Now all it will do is print the alignment sheets and won't let me copy anything. The...
alighment not sucessfully completed because of one of the catridge nozzles are clogged or carriage assm not reading the align page properly,check the align page is properly printed? if no repalce catridge, if print quality is good clean align reader which was located beside of the carriage... best of luck
Sep 07, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My printer simply wont print, I just get blank pages even when printing the test page. I have tried cleaning, deep cleaning nozzle alignment, everything!
HI there,
It sounds like you've done everything right, and it still won't print. Your printer is dead - and you need a new one.
May 19, 2011 | Office Equipment & Supplies
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP C6180 won't align print cartridges
hi Alignment of ink cartridges is very essential for the for the printer to print so first of all be sure that you are using geniun ink cartridges now lets try a reset on your printer press the # and 3 button on your printer together and then unplug the power cord from your printer and keep pressing the buttons now wait for 5 sec and while pressing # and 3 replug the power cord wait for the printer to initialize and see if it prints alignment page if no page is printed then click on the start button of the computer and then go to printers and faxes and then right ckick on the icon of your printer and click on printing preferences now go to the features tab and click on the button that says align print cartridges wait for the alignment page to print and now try and see if it prints fine
Aug 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp Photosmart C3180-start-up
Okay, just chatted online with an HP tech, and she helped me solve the problem!
She said: the printer prints an alignment page everytime you turn on due to incomplete initialization process.
Turn off the printer and Turn on.
Please unplug the usbcable.
  1. Lift the scanner lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass.
  3. Place the alignment page face down
  4. Close the scanner lid of the printer.
  5. Press the Scan button.
  6. The On/Resume light will blink during the alignment process.
  7. After the On/Resume light stops blinking, alignment is complete.
  8. Turn off printer and Turn on.
It shouldn't print the alignment page any more! :)
Hope this helps!
Jan 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
