Question about Frigidaire FEQ1442ES Electric Dryer
Frigidaire LEQ1442ES dryer, beeping 3 times, not working!
I have just bought the above mentioned dryer as a scratch and dent. It had no manual or info included. I attached the power cord and vent. When I press the start button, it beeps three times, and the end row of lights blink with the beeps. I assume this is a code of some sort, but, I am obviously ignorant of what it is indicating. Any help would be greatly appreciated. By the way, I am finding that this dryer goes by model # FEQ1442ES. My dryer's Model number is as listed with the first letter as L. I imagine this is simply a yearly model # change for the same dryer.
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
jyackle5
  • 8197 Answers
SOURCE: PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Posted on Oct 05, 2009
SOURCE: clean lent filter keeps beeping
it stops in 10 seconds
Posted on Oct 11, 2009
SOURCE: Frigidaire FEQ1442ES dryer beeping three times and
I have the same problem with the same dryer, but don't know why either. I was reading on one posting that a button might be stuck so the dryer thinks the button is constantly being pressed.
Posted on Jan 25, 2010
SOURCE: My Frigidaire FEQ1442ES1 dryer has started to beep
When I read to manual, it said it was the lint. I use a paint brush to brush the lint off and usually the beeping stops.
Posted on May 05, 2010
My Frigidaire dryer beeps 3 times
If it beeps three times, but does not start, it "thinks" the door is open, you must test the door switch circuit... Door Switch 134813601
Jul 08, 2016 | Frigidaire Dryers
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
Dryer turns on then shuts off
Hello - The following could be reasons for your dryer to stop working; there could possibly be a malfunction in the thermostat in the return, so if it gets too hot on the auto dry cycle, it stops and will not re-start until it cools down. This could be caused by either lint or something else clogging the vent thus causing it to overheat. You should be able to feel the top of the dryer right at the back of the top near the console right after it shuts off. If it is getting too hot to the touch look to the items I have mentioned. Should you find that these suggestions are ineffective, may we suggest contacting a professional to move forward accurately who will be able to diagnose the problem.
Oct 24, 2012 | Frigidaire Electric Dryer
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
My frigidaire LEQ1442ES dryer runs tumbles but would not heat. Cleaned out vent, reset the house fuse not won't turn on, lights flash only.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 29, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer works for 20 sec and then beeps 6 times and stops
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134420600es.pdf
this is a web site with you manuals. check it out and see if this does not get you started.
http://www.frigidaire.com/manuals
here is another with more manuals.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efs.pdf
this one reads the error codes.
Good luck.
May 01, 2010 | Frigidaire FEQ1442ES Electric Dryer
LEQ1442ES--Nasty Smelling Clothes--Major lint inside
They make a 'air vent' lint cleaner and there is a handy brush made for cleaning your fridge coils that would work great. After you clean it, toss a 'Bounce' dryer sheet in to freshen it up!
Jul 08, 2009 | Frigidaire FEQ1442ES Electric Dryer
LG WASHER AND DRYER LGWN1812CW&LGDLE2512W
hi there
i e-mailed you the one for the washer but im having a bit of problem with the dryer, as the model # that you provided does not exist. would you mind re-checking it for me please?
thanks
Sep 30, 2008 | LG DLE2512W Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
279 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
