Question about Belkin Computers & Internet
Belkin wire does not work when connected from laptop to tv
What kind of wire is it?
Posted on Oct 13, 2008
My belkin wireless router cannot connect to my to samsung tv, why?
More than likely your network settings on your TV aren't set correctly. Also, double check for the wifi signal if wireless or ethernet cable if you used a wired connection.
Jul 05, 2014 | Computers & Internet
Can you run a seperate router for your dvr and another one for computer wired connection
It's hard to tell exactly what you have but it sounds like you have DSL on the 2wire. If everything is hard wired you can use the LAN Ethernet ports on the Belkin as a switch. You should to assign a static IP on the Belkin for management purposes and shut off its DHCP server. The static IP should be something in the range assigned by the 2wire but out of its DHCP range. Like 192.168.0.5 You will not need the WAN port on the Belkin. After you reconfigure the Belkin connect the Ethernet port on the 2wire to it. Along with your PC and DVR. I think it has 4 LAN ports so that will leave one open. It would probably be easier to buy a switch at the store.
Dec 15, 2013 | 2wire (1000-400108-001) Router
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
Jan 04, 2011 | Belkin F5D7050TT Wireless Adapter
BELKIN F5D8236-4 V2:Router keeps loosing wireless connection
hi..
check the range in which you are using the laptop.please use the laptop within 6 meters if you go more than that it is difficult to recieve the signal.
if stil the problem presists then try connecting with wireless internet with some other laptop if the problem presists then it the modem problem service or replace it. if it works fine then the problem is on laptop.check with the dealer.
if you are satisfied with my answer please vote
Jul 13, 2010 | Belkin F5D8236-4 Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin router not working with Mac Laptop
Try Changing the Security Mode into 64 Bit WEP
And also Make sure that WPS is disabled
Jan 07, 2010 | Belkin F5D7234-4 Router
F5D7230-4 wired laptop wont connect
It is not a router configuration problem its a laptop problem in the configuration. Do you have the network card installed if so try a reinstall. if not go to your network wizard and set it back up .
Oct 07, 2008 | Belkin (F5D7230-4) Router (587009)
Dont know how to connect the my windows XP laptop to my Panasonic Viera HD TV using the BELKIN PC-DVD to TV cable.
if your laptop has a s-video output you can use a standard s-video cable to connect to your tv.
Aug 30, 2008 | Belkin Computers & Internet
Belkin router54g 75d7230-4
As long as the computer you are connecting has the capability to connect in some form, wireless or wired, you will not have to run the web utility again. However, if you are currently connecting your laptop wirelessly, and you are connecting your other computer with a wired connection, you must make sure that the wired network is not disabled.
May 01, 2008 | Belkin (F5D7230-4) Router (587009)
Router not working unless
Several questions --
How is this wired?
Comming from the Cable (tv) or a phone wire (DSL) from a phone jack you are connected to a modem/whatever supplied by your service provider. Then an ethernet cable (looks like a fat phone cable with extra wide connectors (8 metal connectors instead of 2 or 4) connects the modem/whatever to your router's WAN port (the separate port not one of the block of 4) and another ethernet cable connects the one of the outer's Lan ports (probably block of 4) to the desktop computer and your laptop operates wirelessly. Is this correct? If not explain houw this is wired, please. For consistency please start at the cable or phone wire.
Does your desktop do anything to log into the internet with a userid and password maybe?
If so who is your internet service provider?
We may need to change the login process and get it into the router and off the desktop.
Jan 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
21 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
