RCA 257003 Remote Control Logo
Posted on Oct 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA Universal Remote set to my Emerson TV
I want to set my Emerson TV to work with my RCA Remote. Where do I find the code to do this?
  • Janice0007 Oct 12, 2008
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14309
Points
I need to know my RCA remote codes for my Emerson tv .
Anonymous
Level 3:
Genius:
  • Master 1,124 Answers
  • Posted on Oct 12, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1124
Questions
0
Helped
364588
Points
3197
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
  • lil_ladyb570 May 14, 2011
    I still don't understand how to set this up! My tv is Emerson the remote is RCA. all I want the remote to do is volume and change channels. How the heck do I make this happen! Please help I'm desperate
  • Anonymous Jun 25, 2013
    I get my tv to turn off , but it will not turn back out? Please help. Ive redone it about 5 times and it just keeps cutting off but will not turn on -___-
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14198
Points
What is the code for emerson hd tv on rca remote control
4 Related Answers
A
Anonymous
  • Posted on Sep 14, 2008
SOURCE: RCA RCR451 UNIVERSAL REMOTE
wanna scan those rca codes for me
Anonymous
  • 360 Answers
  • Posted on Feb 17, 2009
SOURCE: GE Universal Remote - Have codes, not working
you will need to manually find the codes with a code search. If you do not have the owners manual, let me know, I will attempt to find it for you and post a link. Let me know
Please take the time to rate this solution.
clarkco
Anonymous
  • 2712 Answers
  • Posted on May 22, 2008
SOURCE: having problems programing rca remote
Try these codes for Emerson TV: 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Anonymous
  • 231 Answers
  • Posted on Dec 24, 2008
SOURCE: RCA Universal Remote
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
3answers
NH305UD. How can I program it?
Universal Remote Control Codes - Emerson Instructions
www.remotecodelist.com/remotes/emerson/emerson.html
Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For ... Emerson multi-brand remote codes for tv's.
Remote Control Codes For Emerson TVs ' Codes For ...
codesforuniversalremotes.com/universal-remote-control-codes-emerson-t...
2 & 4 Digit Universal Remote Control Codes For Emerson TVs Emerson multi-brand remote ... How to Program a Universal Remote Control : Universal RemoteProgramming of TV ... Can you give me the code for Western digital TV box please.
Emerson brand TV remote codes - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../Emerson...TV-remote.../784589
May 22, 2010 - I have a Emerson TV model # BLC320EM9 A and I cannot find a ...http://www.bing.com/shopping/logitech-harmony-300-universal-remote-control/p/7E7752820C88A8C05005?q=. ..... I can not get 11864 to work with the silver xfinity remote that has the ..... Code 11864 was not listed in the program guide.
I want to program my universal remote to my Emerson TV (LC220EM2)
Hi all.
1. You must find the model number of your RCA universal remote.
2. You must search RCA.com for it or else google.com for "[model number of RCA remote] + operating manual"
Ignore all those who listed codes.. they have no idea what universal remote you have. All universal remotes have different code databases.
BTW... You most likely will not get any universal remote to work well with your TV. When you get done fiddling with universal, know that you can always purchase the OEM remote from link below (guaranteed to work without programming): SYLVANIA NH001UD Emerson LCD TV Remote Control
2answers
Ok i have a rca remote trying tp program it to a emerson tv do not have any codes
Here are some codes for your Emerson TV.
065,067,075,076,079
Here are some instructions as well for your RCA Remote:
Hope that helps.
Do you have a RCA D770 code for an Emerson LC320EM9 TV?
Hello cheflounder,
Here are the codes for Emerson:
011,026,027,028,029,030 046,088 031,032,037,042,053,064
Hope this sorts you out. If so then please leave a thumbs up.
Cheers Little Dish Fitter
I cannot get my Universal remote to work with my tv.
try these ones.
0154, 0236, 0463, 0180, 0282, 0178, 0019, 0179, 0039, 0177, 0185, 0280, 0623, 0624
those are the codes for Emerson Tv's
hope this helps
Cheers
Little Dish Fitter
2answers
20helpful
4answers
Need code for Emerson TV,DVD,VCR Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
