Question about Dryers
Kenmore Dryer - Series 80 - Model 96586200
The dryer is leaving brown streaks on clothes. Any ideas on the problem? And is the solution an easy and cheap fix - or should we replace since it is 12+ years? We had similar issues w/ the washer and the repairman said to purchase new given age of machine. Also, damp hot air is coming out from underneath as well. Any advice is much appreciated.
Kenmore Series 80
Model #96586200
Stock# 65862
Serial# ME0616032
  • 725 Answers
The brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Posted on Oct 12, 2008
My dryer is leaving brown stains on my clothes. I think that the drum needs to be aligned. Is this an easy task?
If your dryer is leaving small brown streaks on your clothes, then your drum seals need to be replaced. It is not a hard task if you know what youre doing. It is a complicated one for a beginner because you have to take your whole dryer apart to replace the seals
Jul 13, 2011 | Dryers
We have had this dryer for 6 years and for the last year it has been leaving brown marks on our clothes. The brown streaks will not come out easily. We have cleaned the dryer on the inside but this has not...
This is usually from the clothes being pinched. Either in the front or rear. The front uses a glide type system on GE style dryers and felt and rollers on most others. Here is a link. Check the type of dryer you have or send me the model # and I will direct you, then follow the links in the troubleshooting to the video that fits your dryer. If you enter your model # you can also get diagrams and illustrations that will also show you what type of dryer. The repairs are easy to do and inexpensive.
Jun 15, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Hello I have an 2004 HE4 Nat Gas smartheat quick pack 9 model 9587 / 110.9586. It seems to be leaving brown markings or streaks on the clothes more and more frequently any ideas on how to best deal with...
the felt seal part number 697694 could be worn,if the drum sags down from the felt wearing down it forms a gap and the clothing can even get stuck in gap,some dryers have glides that wear down and some ride on a back bearing,but the problem usually is from a part wearing down and a gap forms from it and it damages the clothing,hope this helps
Nov 06, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
399 people viewed this question
Top Dryers Experts
