Question about GE GSS25JEMWW Side by Side
Ge Freezer not working
My GE side by side is having problems. The refrigerator seems to be working, but the freezer is not. I can hear a fan working. What steps should I be taking to fix the problem?
  • 1 more comment
  • Lina711 Oct 17, 2008
    The ice maker stopped working but the water still works. I can hear the fan but water keeps leaking on the floor. Not sure what the problem is, please advise. My actual model # is GSS25WGMDWW but I didn't see it noted.
    Thanks,
    Lina
  • LPMUNOZ07 Oct 23, 2008
    ge model TFX27R FREZZER AND REFRIGERATOR, SIDE BY SIDE DOES NOT COOL. i STOPED USING FOR TWO WEEKS AND WORKED AGAIN FOR TWO WEEKS AND I HAVE NOW THE SAME PROBLEM
  • Lina711 May 11, 2010
    Now the freezer is not cooling at all. The fan is blowing but warm air is the only thing flowing from it.
The temp in my freezer is staying around 32-33 degrees . it is a ge model
#GSS25JFMD CC please help
Posted on Oct 18, 2008
    Problem Solver:
  • 3 Answers
With min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Posted on Oct 12, 2008
I have a GE PROFILE pds22mhr and the freezer seems to be getting warmer. I took the back panel off and places some house fans on the coils and it seems to be dropping in Temp. I think the fan is no good...
Listen in the freezer side for the fan if you cannot hear or feel the air or fan running you probably need to replace it. Remove the back panel in the freezer to access the fan motor.<br /> <br /> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a> </span>
Aug 31, 2010 | GE Profile PDS22MHR Bottom Freezer...
Freezer will not get cold
Hi..
You need to check this following:
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
Good luck !!!
Regards
PCmania
Jul 10, 2009 | GE GSS25LGM Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
GE refrigerator model PSS27MGMBB Freezer is not working
Open the freezer door and look at the back wall. If there is frost on the back wall, you have a defrost problem, which means air cannot circulate over the cooling coils located behind the freezers back wall. You will have to remove the back wall and melt all the frost with a hair blower, then replace the defrost heater. (part number WR51X10055) . This is assuming that the fan by the compressor and the one inside the freezer are working.
Jul 01, 2009 | GE PSS27MGM Side by Side Refrigerator
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Is not cooling
you may have defrost problem hear if compressor morking
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator stopped cooling
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Jun 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
1,303 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
