Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
60" LG Lcd Projection TV
My TV has developed a yellow spot in the center of the screen about 3' long and 2' wide. As white images move into this are they turn yellow and then again white as they move out of this area. From previous discussions you posted I assume I have a faulty light engine. Is this a common problem with LG? Thx.
  • louconner Nov 15, 2008
    I have the same problem and am developing more yellow spots. The picture is also getting dull. Is this something I can work on myself? It's out of warranty, so why not, right? Where is the cheapest place to get a bulb? Is a bulb and a light engine the same thing?
    louconner@cox.net
  • kalpesh4747 May 11, 2009
  • 38 Answers
Ok u could have somthing on the lcd srenn and thta is y u have a yellow spot what i would do first is pull out the unit and look at the luc screen and buld to see if u have somthing on it i could be a small pice of papaer or anything it is best if u look at it thru the lens on the inside on the tv when u have it on because u can see i t better i hope this hps marty
Posted on Oct 13, 2008
I have a tv lg ru-60sz30 with yellow spots on the image. I guess it's the optical block
yes the yellow spots mean its a optical block problem. in your case it is the yellow LCD panel inside the optical block. this is not a diy fix you need special tools to realign the panel. sorry for the bad news.
Apr 05, 2011 | LG RU-60SZ30 60" Rear Projection...
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Yellow-green spot in center of screen
Defective light engine. Contact Sony support. They warrantied a lot of these sets even after the warranty had expired because of so many going bad after 3-4 yrs. Have the complete model and serial number ready when you call them.
May 20, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
60" zenith tv
Call LG electronics, they bought Zenith and fixed my 60inch Zewnith for free , my model is D60WLCD
Jun 07, 2008 | Zenith D60WLCD 60" Rear Projection...
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Feb 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Jan 03, 2008 | Hitachi 50V710 50" Rear Projection...
Zenith lcd with a yellow dot
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
Dec 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
452 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
