Kenmore Series 80 agitate for 10 seconds and pause for several minutes
I recently acquired a used Kenmore Series 80 washing machine. I did 3 loads just fine and the 4th load started this.....it will agitate for 8-10 seconds and then pause for several minutes. It continues this process for the wash and rinse cycles....it will eventually drain and spin out.
WHen I initially hooked it up the water came gushing back out of the drain (that I finally figured out was a plastic piece designed to keep the water from coming back up was inadvertantly pushed down about 8 inches into the drain. But before I figured that out I put another drain hose from my last washer onto this washer and it had a smaller end on it so the water didn't come up out of the drain anymore......BUT on the 4th load the pressure expelling the water out of the washer was so great that it blew the drain hose off of the back of the washing machine!!!! Water gushing all over the floor and the basement!!!!)
The question ... is there a sensor that could have gotten messed up when the wrong size of drain hose was on the washer? And would it still be acting that way even though I have the proper drain hose on there and it is draining properly now?
  • xzlr8ng Oct 12, 2008
    Thank you SearsTechToo, it appears that the pause is happening in all the cycles and within each section of the cycle. It doesn't appear to be the switch. It looks like the timer is not moving as it should.
Ok that does sound like the solution when it gaps or pauses in different cycles, you can order a timer with a model number here. www.apdepot.com Under keyword timer it shows 51 different timers for a kenmore.
Posted on Oct 12, 2008
    Novelist:
    Champion:
  • 261 Answers
No, the most is a damaged pump, does it pause in agitation or just spin? I would check the lid switch and timer.
How do I tighted the agitator on my Kenmore 80-series washer?
Most top load agitators have centre bolt on them and it is special bolt inside agitator and you must use proper socket with extension to reach bolt and holed agitator with one hand when tithing the bolt
Dec 09, 2013 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore 80 Series washing machine agitator is not moving much
sounds like you motor coupling may have broken, part is about $20
Jan 17, 2010 | Washing Machines
Kenmore 80 series washer clothes are still dripping wet
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
