It will start like everything is running fine for about 30 secs then it will beep and F4 is in the display. What does that mean and how do I fix it?
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
SOURCE: Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
