Question about NetGear WGR614 Router
How to find my key code to hook up laptop - NetGear WGR614 Router
  • 2,460 Answers
Go to a machine that is on the network and login to your router. www.routerlogin.com comes to mind. The default username and password is admin and password. If you've changed the password away from it, you'll have to use that password instead.
Once you get there, you should open up the Netgear Smart Wizard with blue tabs down the side. The second category is Wirelss Settings. When you click on that, it displays a network name (SSID), a security type, and a wirless key that you have set.
For example, mine is set to WEP 64bit Automatic and I have a simple 1011121314 key in key 1.
My house is also 1 of 4 in a cul-de-sac :-)
Carl
Posted on Oct 12, 2008
I have a 2010 Fiat Ducato and need a spare key fob unfortunately I do not have the key code. How do I go about establishing the code?
You have to have laptop and the stuff to hook up to the car computer a locksmith can get you the code also
May 14, 2017 | Fiat Cars & Trucks
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
Just got a new laptop need the security key for this router. A year ago, the cable guy came to my home and hooked up my sons laptop and wrote the security key down and now I have it, but cannot read his...
If you can't figure out the security key then you can reset the router. There should be a small button probably inside a little hole on your router that says reset by it. Press that with something small like a paperclip and it will be set back to the default settings.
May 10, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
I am trying to hook a laptop to the projector
before you hook it up set the resolution on the laptop to a lower one (1024x768).
Connect the laptop to the projector
Then on the laptop hold down the FN key whilst pressing the correct key (F5 on an Acer) the key usually has two screens on it.
Doing that set of keys repeatedly will cycle through the following
LAPTOP ONLY
LAPTOP PLUS EXTERNAL DISPLAY
EXTERNAL DISPLAY ONLY
For some older projectors you may have to reduce the resolution even further eg (800x600)
Hope this gives you the information you need
Bob
ExMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Jan 01, 2010 | Sanyo PLC XU35 Multimedia Projector
I have a Gateway 7322 laptop. I'm trying to hook
Press the Fn key down, hold it down, then press the F2 key.
Here is the download page for the Gateway Notebook User Guide,
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4429ul.shtml
Aug 05, 2009 | Dell Inspiron 1525 Laptop
I also need the 25 digit product key
HAckers paradise may have a key but that is a jungle of viruses to get to that realestate
Aug 01, 2009 | Compaq Armada M700 Notebook
My laptop's screen suddenly went white.
On your laptop, there are function keys. on mine, I have "fn" near the control key. Then you will notice there are corresponding (usually by color) for the functions. My laptop allows me to change the output of the screen in three ways:
  1. Display properties in control panel (you cant see those though!)
  2. Hook up the vga to external monitor, turn the computer on until it is booted, then close the lid
  3. pressing fn and the key that says "crt/lcd". For me it is fn/F8
Jul 11, 2009 | CMB T43 750 Notebook
Trying to hook laptop to tv
try pressing FN key and F8 key to switch between screens. If that doesn't help right click on desktop, select properties, settings tab, click advanced button. there may be something in there to force the TV.
Dec 21, 2008 | Dell Inspiron 8000 Notebook
NetGear WGR614 Router Logo
573 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
