Question about Whirlpool 10 cu. ft. / 283 liter Chest Freezer EH100FXKQ
Chest Freezer not cooling
Cools at the top but not at the bottom. Whirlpool 7 CF, Model EH070F.
  • 1,543 Answers
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Posted on Oct 12, 2008
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
My whirlpool chest freezer not freezing at all
it not freezing because it cooling system must be damaged,you bought another cooling machine it has mini size and it fixed at the point of older cooling placce.
Mar 22, 2013 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Top portion of whirlpool chest type freezer is cooling but bottom not cooling
Check t'stat setting . Adjust and if it doesn't correct it, then probably the t'stat is bad. If it 9-10 years old, then replace the freezer. This could be the beginning of the end.
Jan 27, 2013 | Freezers
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
I have Haier 5 cubic foot chest freezer, model # HCM050LA, that cools well with the green light on. When it is running it makes a very faint high pitched sound that seems to be coming from the top right...
Yes it does. It will have to be blowing inside so look in there. You will have to take the cover off.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Whirlpool rsb21 fridge freezer
I would be willing to bet that the cf stand for compressor failure.
Apr 06, 2008 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Whirlpool 10 cu. ft. / 283 liter Chest Freezer EH100FXKQ Logo
620 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
